Vararam
Old 12-30-2016, 12:01 AM   #1
phinsfan64
phinsfan64's Avatar
Drives: 2019 Grand Sport
Help Lowering Please
Sorry I'm a newbie in the suspension department. Just changed from 22's to MMR M228 20's.Car needs a bit of an altitude adjustment now. Nothing crazy as its my daily driver as wel as low 11's on track days (With completely different wheel & tire setup). Looking for ideas to achieve my goals. Thanks for the help!
phinsfan64 is offline   Reply With Quote
Old 12-30-2016, 12:39 AM   #2
Zombie killer
Emerald Coast Camaros
Zombie killer's Avatar
Drives: 2013 2SS/RS L99
1" drop springs are the cheapest way to obtain the "look". If you don't want to gain negative camber above the factory setting in the rear you might also want the LCA for lowered vehicles to get that adjustability back. Beyond spring change , you begin down the path of coil overs and how much you want to spend ... and on whether you want the looks or actual performance or something in between.
Zombie killer is offline   Reply With Quote
Old 12-30-2016, 06:02 AM   #3
justjoshin
justjoshin's Avatar
Drives: 2010 SW 1SS L99 Camaro
I second 1" drop springs. Gave my car the perfect stance.
justjoshin is offline   Reply With Quote
Old 12-30-2016, 09:27 AM   #4
phinsfan64
phinsfan64's Avatar
Thanks for the suggestions. Since I'm more into 1/4 mile than road course, the 1" drop springs sound like the best route for me. Again sorry newbie at suspension, whats the LCA?
Any suggestions on brand?
Thanks
Tom
Old 12-30-2016, 09:35 AM   #5
justjoshin
justjoshin's Avatar
I went with the 1" Hotchkis springs for my 2010 SS.
Old 12-30-2016, 08:25 PM   #6
Zombie killer
Thanks
Tom
LCA = lower control arm
Thee are a few manufactures out there. BMR makes a set for lowered cars that is relatively affordable.
Old 01-02-2017, 07:51 PM   #7
macnroxy
Drives: 2015 2ss
just got the 1 inch BMR springs, justjoshin did yours align ok or did you need the camber bolts? Going to do this in my garage with a floor jack big project? any concerns or tricks to make it more straight forward? Thanks guys
macnroxy is offline   Reply With Quote
