12-27-2021, 09:19 PM | #57 |
Drives: 2022 1SS 1LE A10 BCD WCT+PDR Join Date: Mar 2008
I see in post #51, on the left side of the Aim screen shot, there are a bunch of PIDs. Are all these available? And I see you are getting brake pressure, steering angle, throttle % too which are great PDR data points.
Did you use the C7_Stingray ECU Profile? Any reason you went with the OBD instead of the CAN bus other than install simplicity? Thank You
12-28-2021, 06:02 AM | #58 | |
Drives: 2021 1SS 1LE Join Date: Nov 2020
When I coach, I use this with multiple clients, so it is easier just to plug and play. Ken |
12-28-2021, 09:42 AM | #59 |
From what I can tell, there doesn't seem to be any difference in OBD vs Can connection...
Ken |
12-28-2021, 10:31 AM | #60 |
i still need to get a laptop so i can download my aim date and edit/review my gopro footage better also do you ever use racer360 and what do you think about it?
12-28-2021, 10:34 AM | #61 | |
https://racers360.com/coaches/ken-hill/ I'd be be happy to do a Camaro6 Zoom going over data if everyone wants.... Ken |
12-28-2021, 10:54 AM | #62 |
thanks ken you sound like an awesome guy and driver wish you were closer! haha
12-28-2021, 11:09 AM | #63 |
Great info Ken! Thank You!
01-20-2022, 09:42 AM | #64 |
Jan 2022 update -
The car is at the dealer for servicing. All fluids, and some sort of transmission leak(?) as well an updated alignment. I want to keep a track record of having the dealer do the servicing for at least the first year. SO lucky I have a local dealer that has a performance mechanic that has a true interest in may car. I purchased SPL rear toe rods he is going to install to get more alignment camber from the rear and bring the front up to match. I also was in on the new Forgeline Apex wheel buy and have a set of 18"s on the way to run scrubs. Hopefully I can get it out for a day in Feb or March! The plan to test for Feb- May will be - - 19" SC3r with the new alignment - 18" scrubs - LT2 intake and tune. Ken |
01-20-2022, 10:07 AM | #65 | |
Drives: 2020 SS 1LE Join Date: Aug 2020
Excited to hear your experience. You going to run square? Also curious how much neg camber you’ll get on stock components and spl rods. Going for something like…. -2.6, 0” toe F and -2.0 1/16” toe R? |
01-20-2022, 10:30 AM | #66 | |
cant wait to see what you can do on some 19s and 3rs are you going square or staggered?
01-20-2022, 10:40 AM | #67 | |
Drives: 2017 Blue Camaro 1SS 1LE with PDR Join Date: Sep 2018
Thanks for posting details and data in this thread! I'm enjoying following it.
Those two items along with a flex fuel sensor/E85 map are tempting upgrades for me once my warranty expires if I eventually get to the point where I stop improving on my lap times with everything stock. At -2.5° front alignment, you are probably within 0.3° of maxing out front negative camber if it isn't maxed out already. Are you planning to get camber arms and/or do the strut mod plus elongate the two adjustment holes on each side to get more range of front adjustability? Last edited by cdrptrks; 01-20-2022 at 10:55 AM. |
01-20-2022, 11:03 AM | #68 | |
01-20-2022, 01:11 PM | #69 | |
The current alignment I have run is .-2.5 and -1.7. The GM tech that ground the front struts said he could get -3.0 out of the front, but was limited with the rear. Our plan is -3.0 and -2.25 with zero toe again. Ken Last edited by khcoaching; 01-20-2022 at 01:27 PM. |
01-20-2022, 01:21 PM | #70 | |
I decided to keep the car in warrantable fashion until mid year, maybe a bit, longer. I have some goals with it without tuning and want to see how far I can take it. (He mentioned installing the LT2 without a tune and it be fine...) I do have a E85 setup, not installed, but E85 isn't available here, so I will hold off until it gets tuned, probably mid summer if I reach my goals. Strut mod was already done. Without it, I was stuck at -1.7 in the front. Ken |
