12-04-2023, 10:13 AM | #1 |
Drives: ‘22 SS1LE M6 Join Date: Nov 2021
Wheel Spacer Options - 26 mm
Anyone know of an equivalent alternative to Apex’s 26mm wheel spacers…to run a square wheel set-up ? Apex’s are back ordered. Also open to a used pair of Apex 26mm spacers. Thx
12-04-2023, 10:46 AM | #2 |
Drives: 2018 Camaro 1SS 1LE Join Date: Sep 2018
Get these and hammer out the studs that come with them, throw out the studs and lug nuts and use MSI or ARP studs and MSI lug nuts.
I used the 1.5" spacers to fit an 18x12 square setup with the MSI 97mm Mustang studs. Worked great! https://www.titanwheelaccessories.co...studs-set-of-4
12-04-2023, 02:32 PM | #3 |
Drives: 2018 SS 1LE Hyperblue Join Date: Jul 2017
I use a set of H&R spacers. tons of others out there. google is your friend..... lol. "5x120 25mm spacer 67mm center bore"
12-04-2023, 07:13 PM | #4 |
Found a set. Thanks guys.
12-05-2023, 04:42 AM | #5 |
These guys can make whatever you need for about $135, including hub centric
motorsport-tech.com |
12-05-2023, 07:16 AM | #6 |
Who Needs to KNOW?
if you find dual lugnut version on ebay or similar, knock out china spec studs, drill hole out a bit and bam.. instant machined spacers.
ing for grip.
