08-13-2016, 07:40 AM | #1 |
Hyper Blue 2016 Camaro 2S
Drives: 16 Hyper Blue2SS NPP MagRide 6M NAV Join Date: Apr 2016
Mylink went crazy.
Started a couple days ago I noticed that the infotainment system would stay black for a little bit before booting up. Anyways on my way to work this morning it decided to just start randomly smashing buttons, it started changing stations so I hit home then it opened up the NAV and started hitting all kinds of buttons until it finally went unresponsive. It turns on and plays music, but it's just stuck at the home screen and doesn't respond to any touches on the screen. For what it's worth here is a video of it not doing anything lol. https://youtu.be/1MwT7UzzboM
Will be calling the dealership soon as they open. Not sure why the video isn't working. :/ |
08-13-2016, 07:45 AM | #2 |
Drives: camaro Join Date: May 2013
Did it do this once? Or this is how it is all the time?
Hyperblue/JetBlack |
08-13-2016, 07:47 AM | #3 |
08-13-2016, 07:54 AM | #4 |
Drives: Gen 6 Camaro RS Join Date: Dec 2015
08-13-2016, 08:53 AM | #5 |
Drives: 2016 Camaro 2SS 6M Nightfall Gray Join Date: May 2016
Have you tried the battery disconnect approach?
08-13-2016, 09:31 AM | #6 |
Drives: 2016 Camaro SS Join Date: Jul 2016
There is a calibration update to address this particular issue (no bulletin at this time). Dealer should be able to easily verify if it needs it.
08-13-2016, 10:49 AM | #7 |
I don't know what any of that means lol. Is that saying it's more than likely just an update thing? The soonest they can get me in is Wednesday so I guess i'll just have to do without until then. Hopefully it'll be a quick fix.
08-13-2016, 10:51 AM | #8 |
I was honestly about to do this, but figured that might not actually fix the problem and might just be a temporary band-aid. As much as I hate to, I decided to take it to the dealership and hope they don't jack it all up or take months to fix it... they are notorious for that apparently.
08-13-2016, 11:36 AM | #9 | |
Drives: ^^^This Join Date: Nov 2015
08-13-2016, 11:53 AM | #10 | |
Took about an hour or so to load the file into the vehicle. |
08-13-2016, 12:27 PM | #11 | |
http://www.camaro6.com/forums/showthread.php?t=453662
Past: '99 SS Camaro A4, '73 Camaro 383 A3 "Voices in your head are not considered insider information." 3800 Status - 6/16/16 (Built!) 6000 status - 6/29/16 (Delivered!) |
08-13-2016, 12:38 PM | #12 |
Awesome then hope it goes as smooth as it did with you guys! Thanks for the info!!!
08-18-2016, 12:25 PM | #13 |
Yep so mine got fixed today was simple. Was only there for an hour and 45 minutes. "3025 scanned for trouble codes found dtc u0184 and found #16-na-107" Gibberish to me and probably most of you. They said they did an update and it should have fixed it. Haven't seen it happen again, although it wasn't happening the day before I took it in either. Sometimes it would work fine and sometimes it would either be black screen or buttons just wouldn't respond. Hoping it won't pop back up.
08-18-2016, 01:32 PM | #14 | |
Tags |
mylink |
