12-27-2015, 11:28 AM | #15 |
Drives: 2018 Camaro 1LE Join Date: Jun 2014
Well dang that's a hefty clearance dent!
2018 Camaro 1LE
Nightfall Gray Metallic |
12-27-2015, 01:32 PM | #16 |
Drives: 2011 White 2SS Join Date: May 2011
That's after the motor mounts were unbolted and engine moved as close to the (drivers side) steering shaft after the boot was cut off.
Sent from my iPhone using Tapatalk |
12-27-2015, 02:47 PM | #17 |
Well that's discouraging. Now I'm starting to wonder if the slight benefit is worth it. And here I thought I had my mind made up.
2018 Camaro 1LE
12-27-2015, 03:11 PM | #18 |
Drives: Top Secret Join Date: Oct 2010
I installed 2" Kooks on my 14. I had to trim some studs off the body but the headers fit. Mine were double layer ceramic coated, so it was tight.
I do tuning and stuff.
2014 Camaro SS A6 416 c.i., custom VVT cam, I think a few bolts might be stock still... |
12-27-2015, 03:37 PM | #19 |
Drives: 2014 Saleen 620 White Label #14-011 Join Date: Dec 2014
2" TSPs... put a small ding in cradle on passenger side (after it barely touched when making right turns), no issues otherwise.
'14 Saleen 620 White Label #14-011
ADM LSA Stage 1 Kit, ADM 2.75 Pulley, DEKA 63lb injectors, ZL1 Fuel Pump, JLT 123MM Big Mouth intake, TSP 2" LTHs, BW TB, 2.5" Catback, Scott Culbert/GEN3PERF tuned! 573WHP/557WTQ @ 10psi. Build Thread Here: http://www.camaro5.com/forums/showthread.php?t=390708 |
12-27-2015, 06:09 PM | #20 |
Drives: 13' 1LE Join Date: Apr 2012
Same here with SW; very tight and the underbody needs some hammering to get em in, driver side.
13' 1LE
Old setup: TSP 231-236/Tick 660/.105 PR, UDP, SW LT 2'' & HFC, stock NPP & H pipe, VR-DRX CAI, air scoop, Goertz1 manifold, 102mm BBK, 26" Toyo DRs, Forgestars R17x10 & F18x8, rear seat delete, remote Pat G tune Autocal, 7400 limiter, Spec Mini Twin. 91oct. 11.90@122.3, 0-60ft 2.0 / 11.99@123.6, 0-60ft 2.1 DA+819 ...519RWHP SAE Solid roller SBE LS3, FED, LLSR, 91oct, 605rwhp N/A. Tuned by Pat G. Build by me. |
12-28-2015, 10:18 PM | #21 |
I have installed a few sets of 2" headers and had to clearance for the steering shaft. The passenger side is also pretty tight against the frame rail.
2015 Red Hot 1SS/RS/1LE
ADM LSA kit BTR Stg3 PD Cam Stainless Power LTs w/ CATs Stainless Works ZL1 Res. Delete 3" Retro Catback DST Ported ZL1 TB 619RWHP / 539LB-FT |
