11-18-2019, 07:33 PM | #1 |
Drives: 2010 Camaro 2SSRS M6 Join Date: Jan 2019
Carbon fiber hood
Has anyone purchased or have any thoughts or opinions on the Seibon TS style hood. Or any other manufactures that are known for great carbon fiber work. I’m looking for one that is ready to install “wet”. I don’t want to have to get clear sprayed on it when I get it.
Thanks |
11-18-2019, 10:22 PM | #2 |
Drives: 2010 Camaro 1SS LS3 Join Date: Jan 2015
I've got the Seibon TSII... great looking hood, great fit... has held up great for years now. No fading, plenty of clear coat on it to buff anything out - says my detailer.
You will not regret getting one. Plus... a bit of weight loss... |
11-19-2019, 06:44 AM | #3 |
My Opinion - VIS Racing, Siebon, Anderson Composites are the best. I got the VIS Terminator hood, it was "flawless" and bolted right on with little tweaking for flushness at the Fascia. Reused the Hood Prop rod and W/S Squirter assy. Gelcoat/Urethane finish is awesome, but painted the underside for a finished look. Not worried about hood pins as it is rigid enough and not gonna fly off.
My Deck Lid and Rockers were from Siebon, also nice but not as good as the VIS Hood. MUST inspect closely for damage or cracks UPON delivery, hold the truck driver and open the box to look, cause then if you accept it you own it. These parts DO crack if mishandled. Usually ship from California which is a long truck drive. Note: for owners who my have a small crack like I did on my Deck lid panel (missed it on inspection, right in the middle of the last pic), they can be "repaired" by mixing some thinned out clear Urethane with a little black in it and dabbing the mix into the crack a few times, then clearing with a air brush, wet sanding it, and buff. Can't even tell it is there now. Yeah - I like Carbon Fiber parts. |
12-31-2019, 08:09 PM | #4 |
I have been debating between the two hoods and the vis ams. We’re y’all able to reuse the shock and window spray nozzles without having to drill holes? Spec how high is the scoop on your hood? Is it close to factory height or higher?
01-01-2020, 01:34 AM | #5 | |
LSx FTW!!!
Drives: 2010 Camaro 2SS RS Join Date: Jan 2017
2010 2SS RS A6 781rwhp on E85
Stage 2 ProCharger D1X Circle D 3400 Triple Disc Kooks Jet Hot Headers Kooks Full 3in exhaust Trick Flow GenX 255's Polished PAC .660's & Ti-retainers TSP VVT 3.2 cam kit w/DoD Delete Smith Bro's Trunnion kit AEM X-Series OBDII Widebands FIC ID1300x Injectors GM ZL1 High Output Fuel Pump DSX Tuning Flex Sensor DSX Auxiliary Fuel System Tim King Stage 4 Max Effort CTSV 6L90 DSS 1 piece aluminum driveshaft JRE 6L80E / 6L90E Dipstick NGK Iridium IX spark plugs #7 heat range Mighty Mouse Camaro 5 Wild w/-12an and Billet Black HP Tuners VCM Suite |
01-01-2020, 03:40 AM | #6 | |
Sorry I missed this the first time... Short answer is YES - I was able to reuse all hardware... plug and play, including the water line equipment, prop bar, and hinges. No new holes had to be drilled... it was amazing to me how well made this thing was when I first installed it... and the perfect fit. You will not regret getting the SEIBON. The Cowl height is the same as stock... the vents are fully functional, and come with covers (on the underneath side) that are installed by fasteners. |
01-01-2020, 10:34 AM | #7 |
Drives: 2010 Black 2ss Camaro SS Join Date: May 2010
Anderson and VIS are the only two to look at. Just remember to get a good set of hood pins and a good carbide pit to drill through the carbon fiber.
ZL1 10 spokes,Dart 388,ECS Supercharger 2200x, E85 Flex Fuel sensor, Dart 388 , B&M Tranny Cooler, Vigilante 4000 Triple Disc TC,Katech Ported Heads, Texas Speed Sheet Metal Intake, ECS Big Blower Cam,ID 1700s, Fore Triple Pumps, E85,ATI Super Dampner, KW V3 Coilovers, Pfadt front and rear sway bars,Pfadt Trailing arms and toe rods,ZL1 Rear Diff, RPM 6l90e level 10 Tranny, SW Long Tubes no cats,Nick Williams Boosted 102mm TB, Dr Phil Tune,Borla Atak
01-01-2020, 11:18 AM | #8 | |
Anderson is SEIBON. Just FYI... Also, hood pins are not necessary on the TSII. "Anderson Composites, a new division of SEIBON International, Inc., located in the heart of Southern California, specializes in carbon fiber and fiberglass components for late-model domestic makes and models with the capability of global distribution. It all started when SEIBON International assembled a handful of SoCal automotive enthusiast to pool their passion and knowledge of domestic muscle vehicles and provide fellow gearheads a new source for late model domestic muscle vehicle components. This vast collection of experience compiled from years of grassroots and sanctioned motorsports (road racing, drag racing, off-road racing and even some motorcycle racing) is driving some of the most innovative lightweight body parts; aesthetically stunning and functional. Anderson Composites sources every product with the upmost attention to detail and only insists on the use of top-grade materials for a quality product. The precision and attention to detail Anderson Composites applies to its products is a science of its own." |
01-01-2020, 02:08 PM | #9 |
I like the fact that the Seibon is able to reuse all of the factory hardware but the extra height of the scoop on the VIS is what has me not knowing what to do. If Seibon was a little taller it would be no question. I don’t think you can just clip the water line equipment etc... onto the VIS.
01-01-2020, 03:30 PM | #10 |
Oh man, so much hood porn.
Is it wrong that I would rather look at Carbon Fiber hoods and trunks than scantily clad ladies?
01-01-2020, 09:03 PM | #11 |
Spec are you running hood pins as recommended? If not then have to had any problems at high speeds. Sorry for all the questions.
01-01-2020, 10:27 PM | #12 | |
I called SEIBON about the required hood pins and they told me they were not needed. Hood fits like stock. Front latch, rear hinges. I've had NO issues at high speeds. |
