10-08-2019, 10:04 AM | #15 | |
Drives: 2014 Camaro 2SS Join Date: Feb 2015
10-08-2019, 10:11 AM | #16 | |
Drives: 2SS/RS L99 BLACK Join Date: Apr 2010
10-08-2019, 10:27 AM | #17 |
See the problem is though, you yourself and I'm sure some other on the board KNOW what your doing, and how your component choices affect other parts in your build, and how the car will behave. Many other people though, do not necessarily know what they are doing, come to the board for recommendations and don't plan on doing any of the maintenance to their cars in that way. They just want to slap parts on it and drive it, not knowing how it will effect drivability, or how certain parts, like valve springs, need checked periodically. So when I see someone ask about a cam, and it's their daily driver, I automatically assume it someone who doesn't really know what they want, because if they did, they wouldn't be asking for cam suggestions on a forum.
10-08-2019, 10:43 AM | #18 | |
10-08-2019, 12:20 PM | #19 | |
10-08-2019, 12:27 PM | #20 |
I'm just in the "keep it conservative" camp because I too, daily drive my vehicle. I really hate a car that has no power down low, but again, its all opinion. I'm in my 40s now and feel differently about driveability, than I did when I was in my 20's. When I was younger, I was much more tolerant to driveability and vehicle behavior on the street than I am now. I like a nice chop or cam lope, don't get the wrong. Just been there done that, over it lol. I don't need a 10 second Street car. A low 12s car is pretty darn quick for a street car. Hell 11s street car is hauling azz on the street. That's plenty fast enough for me, and is pretty easily attainable with milder mods.
10-08-2019, 12:34 PM | #21 | |
GPI Sales Consultant
I agree with you on the gears too - setup is super critical on a rear end, and getting it just a little wrong will wear out a set of a gears and lead to breakage 10 out of 10 times. With these cars I think a good launch technique is also crucial to keeping the rear end alive. These cars won't tolerate a clutch dump, and they won't tolerate wheel hop - they just aren't that strong. I'm a firm believing in a little preload on the hit, takes out all the slack dropping the "snap" of the initial hit, and helping with wheelhop by reducing the "wind up" in every bushing in the rear. I wish we had a 4.56 option for the stock carrier! I have 26" tires on my for the track now - needs all the RPM I can give it!
GPI Max Package 2.0: Brodix BR7 heads/GPI porting, MAX3 cam, ST2116LSR, BSR Max Lift rockers, LS7 LSXR with 103mm TB, Vararam OTR, Mcleod RXT, G-Force/Strange 9" IRS setup with 4.63 gear. 551whp, 11.1@124mph.
Got a question about a GPI product? Feel free to shoot me a message! |
10-08-2019, 12:37 PM | #22 |
Who did you guys, have your rear ends setup by?
10-08-2019, 01:20 PM | #23 |
Drives: 2010 SS L99 Join Date: Sep 2018
GPI did my gears, 3.91
Previous PB:11.079 @ 122.99mph.. New setup time: TBD
The 11.079 pass: https://youtu.be/pz27Zq54t_E Build thread - www.camaro5.com/forums/showthread.php?t=555371 |
10-08-2019, 01:29 PM | #24 |
The first, second, third, or fourth time? Seriously, it's been a bad go for me. The first 4.10 I put in the car was a complete rear end taken out of another car, with something like 40k miles on the gears, some of that while the car was twin turbo. They were Richmond's, which don't have a stellar reputation, and it was an unknown installer. I got a good deal, and it was a great way for me to see what I thought of 4.10s without a big invest. I learned that I loved 4.10s, and they made it about a year, whining pretty good most of the time.
After I broke the first set, I bought a set of Motive 4.10s with the install kit, and found that not a lot of local installers wanted to touch it. I ended up going with a recommendation from a buddy, towing it about 150 miles to a shop, and getting a deal on install for $500. I followed break in carefully, and didn't make a single hit on the until they were well broken in. I added the LPW cover at this point for additional strength. I had about 3,000 miles on it when I lost all pinion preload at a airport drag event. I drove it home like that, about 200 miles. I took it to a local shop I had overlooked, the found a failed crush collar, and resultant dusted pinion bearings. We did new pinion bearings, new crush collar, and sent it back down the road - but the whine was insane. The car has solid aluminum cradle bushings and solid poly BMR diff bushings, and the gears had taken too much abuse when run with no preload and were just awful noisy. So, this spring, I had the rear rebuilt again. I went ahead with all new top end Timken bearings, a trutrac, and gave Yukon gears a shot this time - they have a pretty good warranty. The local shop that diagnosed the failed crush collar on the previous set credited me all their labor trying to make the previous set right towards this job - talk about customer service! They did a great job with the install, showed me the pattern and the lash which were beautiful. I'm about 6k miles into that set of gears and they are doing well. They are still noisier than I would prefer, but I think the LPW cover (with the load bolts right onto the ring gear caps) coupled to the car with all solid bushings just creates a very direct path and transfers any noise. They have around 20 drag strip passes with stick tire 5000+rpm launches on them and seem to take it just fine. I'd love to go a full year without touching the rear end, other than maybe for a fluid change.
10-08-2019, 01:46 PM | #25 |
acammer, it is a huge difference and it showed in driveability. That cam was ground before the Holley manifold, when I was running the stock one but still had bad habits, I wanted top end power but it was too much of a tradeoff for a street car. That's why there's so much debate on "large cams". It depends on what you call large.
I |
10-08-2019, 01:50 PM | #26 |
Drives: 2010 Camaro 2SSRS M6 Join Date: Jan 2019
Thanks for the info. I already had an idea what I wanted to install along with the supporting mods. I have built multiple motors and went to the drag strip most of my life. I have spent my life around cars but the were built specifically for 1/8 or 1/4 mile. I do not DD my car but I do want that to be an option incase I want to hit the road and drive for thousands of miles on a trip. Thanks for the info.
10-08-2019, 04:32 PM | #27 | |
I've always lived by the rule, make as much power as possible, if everything is working right all will come down to tires and throttle control. Never shoot for a dead hook if you're making real power, something WILL BREAK. controlled tire spin is your friend. |
10-08-2019, 05:46 PM | #28 |
Drives: '23 LT1 A10 Join Date: Oct 2015
How bad is my cam? This is for an auto with a 3200 TC.
24 LT1 M6 Sharkskin Metallic
Thread Tools | |
