09-25-2015, 09:42 PM | #15 |
Drives: 2005 C6, 2013 ZL1 2020 Ram Cummins Join Date: Jul 2015
Looking at the graphs the night fury appears to cross the 400tq line about 3300ish rpm, which looks to be a few hundred rpm before the polluter. And the night fury makes peak tq about 500-600 earlier as well. Just food for thought.
09-26-2015, 11:56 AM | #16 |
Drives: 73 VETTE ,, 05 2500hd diesel,14 1LE Join Date: Feb 2014
Something to think about is fuel , in Calli you have 91 not 93 . The boys over at CPR in Mesa AZ have got a cam and tuner that makes the most power on 91 octane weasel piss gas I have seen . They call it a Defibulator or something like that . With headers, cai, ported heads , ported TB that cam, and a Nic D tune they are putting down 500 rwhp with great drivability on 91 octane fuel . What I'm saying is , it is the sum of all the parts and tune that will get your best numbers and performance in a real world situation .
OLD GUY FLYING FAST AND LOW
09-26-2015, 06:58 PM | #17 |
Drives: 13' 1LE Join Date: Apr 2012
Great post OP! Both cam performed great! 480rwhp cam only is nice!!
13' 1LE
Old setup: TSP 231-236/Tick 660/.105 PR, UDP, SW LT 2'' & HFC, stock NPP & H pipe, VR-DRX CAI, air scoop, Goertz1 manifold, 102mm BBK, 26" Toyo DRs, Forgestars R17x10 & F18x8, rear seat delete, remote Pat G tune Autocal, 7400 limiter, Spec Mini Twin. 91oct. 11.90@122.3, 0-60ft 2.0 / 11.99@123.6, 0-60ft 2.1 DA+819 ...519RWHP SAE Solid roller SBE LS3, FED, LLSR, 91oct, 605rwhp N/A. Tuned by Pat G. Build by me. |
09-27-2015, 10:54 PM | #18 |
Drives: '15 Z06, '01 NBM SS, '97 SS Join Date: May 2009
You should have the shop overlay the two graphs.
09-28-2015, 09:24 AM | #19 |
Drives: 2016 camaro 1SS Join Date: Jun 2013
The TSP 235/238 is a monster when it comes to HP gain, Torque suffers a bit but the RWHP increase in unbelievable. Would love to see Dyno numbers for that cam on a stock car.
2016 BLK Camaro 1SS/LT1 M6: NPP | black front/rear bowtie | Blacked out taillights 2011 IOM Camaro 1SS/RS LS3: Stainless works 1 7/8" LT headers w/ Offroad pipes | TSP Cam 235/239 on a 112 | Powerbound 25% UD Pulley Roto-Fab Cold Air Intake | SW Retro Chambered Catback Exhaust | VMax Ported TB | Hurst Short Throw Shifter Trunnion upgrade | LSA Oil Pump | BMR 1.25 Spings | R1 Concept d/s Rotors Tuned by Lashway Motorsports - 501 Hp 430 ft-lb |
09-28-2015, 09:44 AM | #20 |
Drives: 2011 SSm6 Join Date: Oct 2011
Its amazing to me how different dynojets read from one to another. These sheets are listed in SAE format, while I see a lot listed using STD.
But yet both of these sheets read a little higher than they would on the dyno I use. Cam only cars are generally 440 to 460 on that one. And he has alot of them on there. More reason to go by mph at the track when comparing one to another, or control conditions on the same dyno the best you can. Regardless, nice results from both cars. Congratulations |
09-28-2015, 09:50 AM | #21 | |
Drives: Camaro Join Date: Apr 2009
Our new facility is suppose to be finished in November. I'd be happy to set aside some engine dyno time if a bunch of guys wants to show up with different camshafts and we do a all day or two side by side shootout of anything you wanna try. |
09-28-2015, 10:04 AM | #22 | |
Taco's 2014 SS
Mods: 417 Stroker | CAI | Bo's PTB | Kooks LTs | Flowmaster Outlaw Catback | Night Fury Cam | Powerbond UDP | Apex Catch Can |PRC Ported Heads |FAST 102 Intake |Suspension Crap| Built by J-Rod. |
09-28-2015, 10:04 AM | #23 |
09-28-2015, 11:54 AM | #24 | |
09-28-2015, 12:37 PM | #25 |
Drives: 1989 GTA Trans Am Join Date: Jun 2012
"Its amazing to me how different dynojets read from one to another."
A lot of people do not realize that. Also whether 91 octane was used or 93 octane. |
09-28-2015, 04:54 PM | #26 |
Drives: 2015 Summit White 2SS 1LE Join Date: Feb 2012
Reason I like Dyno Days. Everyone one the same day same dyno.
09-30-2015, 03:26 PM | #27 | |
Drives: 2002 Camaro SS Join Date: Feb 2012
For those that like torque, here are some more results from our Polluter: |
09-30-2015, 03:29 PM | #28 | |
Even though it does peak sooner in terms of torque production, at the RPM the Night Fury peaks, the Polluter is no less than 3-5 rwtq behind, and holds that torque longer giving a slight advantage up top. Both are great proven camshafts, and that is what matters. For you guys looking for the best results time and time again, use something that has walked the walked as well as talked the talk. Results are what matters at the end of the day, not so much brand loyalty or shop loyalty in this instance. |
