09-24-2015, 02:45 PM | #1 |
Drives: camaro Join Date: Oct 2013
Nightfury vs Polluter cam dyno results
Attached are two dynos, one polluter one night fury. Nightfury is a friend of a friend's 13 1LE and my car has thr polluter and it's 14 1LE. Same shop, same dyno, different days. These were two cams I was stuck trying to pick one or the other. I thought it would be cool to show a comparison. My polluter also has a fluidampr underdrive crank pulley (does not underdrive the ac).
Nightfury Polluter Last edited by GR8WHITE1; 09-25-2015 at 01:02 PM. |
09-24-2015, 04:23 PM | #2 |
Drives: Camaro Join Date: Apr 2009
Wanna try a TSP 235/239 next to em.
09-24-2015, 04:47 PM | #3 |
Drives: 2015 Camaro SS 1LE Join Date: Aug 2014
Would love to see that ^
2013 2SS RS
CAI Intake Air Scope BMR Strut Bar Tune |
09-24-2015, 06:28 PM | #4 |
Drives: 73 VETTE ,, 05 2500hd diesel,14 1LE Join Date: Feb 2014
Damn close , and good numbers with 91 octane fuel . Too close to make much peak hp difference . Even though the same dyno , 2 diff cars and different days . on any given day they may be different . Would come down to drivability and real world time to speed. And I would pick the one that had slightly less lift that would not be so tough on the valve springs and cam . The way it drives would be the deciding factor .
OLD GUY FLYING FAST AND LOW
09-25-2015, 04:12 AM | #5 |
Drives: 2013 Camaro SS2/RS 1LE Rally Yellow Join Date: Aug 2013
TSP 235/238 all the way. Will make more power
2013 Rally Yellow SS 1LE.
527 RWHP 452 RWTQ Custom tuned by Lashway Motorsports PRC 255 heads, Fast 102 intake manifold, Nicky Williams TB, 25% Under Pulley Texas Speed cam 235/239, SW Long Tube Headers Roto-Fab Cold Air Intake, NPP Exhaust, BMR 1:25 springs |
09-25-2015, 06:11 AM | #6 |
Drives: 2015 2SS/RS/1LE Join Date: Feb 2015
Torque numbers aren't very impressive. Only 10-15 rwtq gain over a typical intake/headers/tune on an otherwise stock engine.
2015 SS/RS/1LE
HSA delete, VMAX throttle body, CAI inc. Intake, PRC255 heads, BTR 660 springs, BTR cryo-treated rockers, PAT G 232/240 .654/.626 110+2, johnson 2110's, Manton 502 pushrods, C5R, Melling high volume/high pressure, Powerbond 25% underdrive pulley, Proform covers, Kooks stepped headers, catless mids, Doug Thorley exhaust. 512rwhp, 446rwtq on a mustang dyno, tuned by Cunningham motorsports. |
09-25-2015, 08:26 AM | #7 |
Drives: 2010 Camaro SS/RS Join Date: Mar 2014
Yeah but it seems the polluter cam holds close to peak torque better than the night fury and for longer. Could be worth something.
2010 2SS/RS
Z/28 intake, NW, FAST 102, speed engineering LT's, some exhaust, ATI -10% pulley, GM flex fuel injectors, DSX flex fuel sensor, MGW shifter, HP Tuners, some suspension work, stickers and a little weight loss. 12.63 @113.53 |
09-25-2015, 08:46 AM | #8 |
Those torque numbers seem pretty good to me.. Larger the cam more horsepower up top but you sacrifice torque.
2010 Camaro 2SS/RS | 416 LS3 | FED stage 2 heads
09-25-2015, 09:28 AM | #9 |
Dyno sheet?
Got a dyno sheet from a relatively "stock" car by any chance?
09-25-2015, 09:50 AM | #10 |
[COTW 5/12/14]
Drives: 2012 CRT NF Cammed 2SS/RS For Sale Join Date: Oct 2011
Oh these are two different cars..... I was thinking it was a side by side. Not bashing or anything, but would need a comprehensive list of both car's mods, etc.
I first read it as a back to back comparison with the only difference being the cam. |
09-25-2015, 10:52 AM | #11 |
That is how it seems to work. But I'm hoping my setup departs from the norm. I love horsepower, but it's nothing without torque. My goal is to break the 500hp barrier by a pretty good margin while also teasing it with the tq number. I'm gonna be running prc255 intake runner heads(vs the 260's to retain intake air velocity), stock intake manifold vs, say, the FAST 102(for the same reason), higher compression, high octane, 11.25:1 compression, and a custom 232/240 .654/.626" 110LSA +2 pat g cam motion cam. High intake lift in a short(er than other popular cams) duration and fairly narrow LSA should also help the tq numbers while not sacrificing hp too much. If I can break 500rwhp quite easily while also running 465-470 tq I'll be a happy camper.
2015 SS/RS/1LE
09-25-2015, 11:10 AM | #12 | |
Maybe you misunderstood why I posted these two. It is not about the numbers that's not why I posted the graphs. All of these larger cams are going to put down near identical numbers. However I wanted to show the small differences in curves and where they are making the power. Both cars have the same mods except I have the fluidampr crank pulley.
This is the dyno of my car before the cam. And you can see the oem cam is giving up the ghost much earlier and the new cam doesn't really sacrifice anything to the oem. Look at the difference in torque at 6500rpm between the polluter and oem, it's around 50ft lb of torque. The oem completely shot it's wad at 4700 rpm. Quote:
Sent from my SM-G900P using Tapatalk Last edited by GR8WHITE1; 09-25-2015 at 02:27 PM. |
09-25-2015, 03:00 PM | #13 | |
[COTW 5/12/14]
09-25-2015, 04:31 PM | #14 |
I'd like to see that. As well as a few others. But we'd need to see the pre-cam dyno numbers and have all the supporting mods as close to the same as possible.
Taco's 2014 SS
Mods: 417 Stroker | CAI | Bo's PTB | Kooks LTs | Flowmaster Outlaw Catback | Night Fury Cam | Powerbond UDP | Apex Catch Can |PRC Ported Heads |FAST 102 Intake |Suspension Crap| Built by J-Rod. |
