08-05-2014, 11:02 AM | #29 |
Drives: C6 Corvette Join Date: Sep 2013
Small cases of them being on the forum here for sale. Doesnt hurt to troll the corvette forum in the C6 section. craigslist...ebay.... just gotta look. they are out there but not the easiest to find for super cheap
2008 C6 m6. Carbon creations front/rear carbon fiber wodebody fenders. Carbon fiber hood carbon fiber roof hoop carbon fiber zr1 extreme spoiler. NW 102mm tb. Ported intake manifold. Cometic .040 head gaskets. LG motorsports G6x3 cam. DSX flex fuel sensor. AEM methanol kit. Z06 brakes. Ebiach sway bars. ZR1 rep wheels and Nitto Invo tires. Monster stage 3 twin disc clutch. MGW short shifter. Corbeau race seats. Gforce race harnesses. SLP loudmouth 2 mufflers. Carbon fiber exhaust tips. RPM stage 4 transmission and Stage 3 rear diff. 3.73 gears. Vararam cai. Kooks 1 7/8 headers and x-pipe.
08-05-2014, 12:08 PM | #30 |
Drives: camaro Join Date: Oct 2013
Found a knockoff site that has wheels you can order in c6 zo6 sizes and wheels are a little over $200 for 18x9.5 with 40mm offset. They have the zo6 replicas but think I might pick up a set of these, would look good with my 1LE wheels.
http://www.corvette-wheels.com/c6-z0...oss-black.html |
08-06-2014, 11:31 AM | #31 |
Grip
I have 17s with M&h drag masters and have a hard time getting 1.8 60s at Fontana when it's cool out. Last time it was in the upper 90s and 2.1 was my avg 60f and low 12s was my best.
Forged LS3 416ci, Maggie TVS2300 @ 13lbs boost, McCleod twin disc clutch, GForce 1320 nine-inch 389 gear ratio, Hurst line-lock, 750 whp 700 wtq |
08-06-2014, 11:39 AM | #32 | |
Sent from my SPH-L710 using Tapatalk 2 |
08-06-2014, 11:41 AM | #33 |
I wanna run at famosa out in Bakersfield.
08-06-2014, 11:45 AM | #34 |
Drives: '10 2SS/RS Join Date: Jun 2014
08-06-2014, 11:50 AM | #35 |
Drives: 2013 SS Join Date: May 2013
M&h are drag radials not slicks. I learned the hard was drag radials can take so much. Best 60ft with mickeys is 1.60 hoping to improve that with a full slick tho
08-06-2014, 12:10 PM | #36 |
Looked like slicks but couldn't tell by the picture.
08-06-2014, 12:13 PM | #37 |
08-06-2014, 12:15 PM | #38 | |
yeah I got about the same results in my 2010 SS too. However, I had to stop after the clutch started acting up. The pedal would get stuck on the floor and wouldn't come up unless the engine RPM's dropped; then it would pop up. 3rd run and it slipped so bad that it smelled really bad and I got a lot of clutch chatter and I was worried I'd not get home. Haha, waited till it cooled down, slipped the clutch a bit on a couple light take offs on the road, and it's normal again. Not going back to the strip again until I replace the stock clutch ... it is my daily driver afterall
mines on the far lane and this was the first time out in this car (bone stock with muffler deletes), lots of wheel hop and spinnage, using launch control. meh, I've been 11's in my other cars, so not really in a rush to get this thing in drag trim yet.
2010 2SS - CAI Intake, ADM Scoop, RotoFab Washer relo. LT Headers and off-road pipes, X-pipe, Muffler Deletes, ZL1 Spoiler, Technostalgia Tail-lights
'98 T/A (Sold) - Forged 6.0ltr, MS3, P&P'd Heads/Valves, 90MM FAST/TB, Headers, 3" Y-pipe, 4" Mufflex Catback. Koni Adjustables w/GC coilovers (550/175), Strano Sway Bars '94 Z28 (Sold) ... LS1 swap (basically same setup as the T/A), TH350/3500 stall ... swapped it all into the T/A -- >> Some of my Projects My Fquick Page |
08-06-2014, 03:41 PM | #39 |
"Cam Only"
I'd go.
2013 AGM Camaro 2SS/RS M6 | LSA Blower, 2.5" pulley, 10% lower, FIC1000's, Fore Innovations Twin Pump fuel system w/ Flex Fuel, CMS Custom Grind Cam, Kooks 1 7/8" headers w/ catless off-road pipes, NPP Exhaust, 3.91's, JLT ZL1 Intake, Prospeed Heat Exchanger | Pfadt Suspension, 1LE Sway Bars | DSS 1000hp axles |
Tuned by Ryne @ CMS E85: 734rwhp/636rwtq (mustang dyno) |
08-06-2014, 06:57 PM | #40 |
I didnt think 17's would clear the stock brembros. How much room do you have?
08-06-2014, 07:17 PM | #41 |
Started a thread about an event in sept.
http://www.camaro5.com/forums/showth...61#post7872761 |
08-07-2014, 11:13 AM | #42 |
They clear but depending on your ride height and LCA they can hit the LCA under a hard launch.
