02-22-2020, 09:52 PM | #1 |
Drives: 2017 Chevrolet Camaro 2SS Join Date: Feb 2020
Spacers help for front rims 20 by 10
So I purchased some new Rims and they kinda scrape the inside because of the size! The stock is 20 by 8.5 but the rims I have is 20 by 10! Do you recommend using spacers if so should I get an inch or lower??
02-24-2020, 02:42 AM | #2 |
Drives: 2017 1SS/1LE Join Date: Sep 2016
What are the offsets? With the proper offset (should be around +20 or +23), you shouldn't need spacers...
02-24-2020, 07:22 AM | #3 |
What are the profiles on the tires? 30? What size are you using on the front!
02-24-2020, 02:24 PM | #4 |
I believe it is a positive offset. I am not entirely sure when I went to discount tires they said when I turn the wheel to reverse the from rims scrapes the inside of the arm I think. He said the stock is 20x8.5 but the front rims I got are 20x10
02-24-2020, 05:29 PM | #5 |
Ask the vendor you bought from what is the offset value they sold you. Your wheel looks like it’s to close to the suspension for the 20x10 size. A lot of people run +23 on the front with the 20x10 wheel. It’s common to have no issues with this configuration on our cars with or without MRC.
02-24-2020, 06:49 PM | #6 |
I'm planning to go 20x10 front with a +23 offset soon myself, hope it won't need spacers. Will post back once I found out.
02-24-2020, 07:04 PM | #7 |
I just did this and had zero issues at all. +23 20x10 285/30 with MRC on my SS. Fit with no issues at all. Put about 200 miles on the car since install and I don’t miss the run flats.
02-24-2020, 08:49 PM | #8 |
Drives: 2016 F150 Join Date: May 2019
The offset and size should be stamped on the inside of the rim. I bet a 5mm spacer would probably make it clear
02-24-2020, 09:37 PM | #9 |
Yeah the guy at discount said to get a 1” 25MM so should I probably go lower? I mean shoot I’ll feel more comfortable getting less than an inch honestly. This is the part I ordered.
2 Pieces 1" 25mm Custom Hub Centric Wheel Spacers Adapters 5x120.7 5x4.75 Center Bore 66.9mm for New Camaro Malibu Lacrosse Regal CTS xTS Equionx - 3 Year Warranty https://www.amazon.com/dp/B06XKW76KJ..._axjvEbSJTRRRS |
02-24-2020, 10:44 PM | #10 | |
My only potential problem is I want to go 285/35 for two reasons, I need to go 315/30 in the rear and I fear the front/rear height difference would be too much with a 285/30, plus I already have the 285/35's and would hate to have to spend extra $$$ if not necessary...
02-25-2020, 01:05 AM | #11 |
I suspect you have the DR-64, if you purchased them from Discount Tires. They make the 20x10 in +23 and +35 offsets. I suspect they sold you the +35, which is far from ideal. If this is the case, I'd highly recommend convincing them to replace them with the +23, as you shouldn't have any fitment issues with that setup, depending on which tire size you went with. OEM fitment on the 1LE/ZL1 is 285/30/20 front and 305/30/20 rear.
02-25-2020, 08:41 AM | #12 |
Unfortunately I actually purchased the tires from facebook. I had just bought the CORSA Xtreme and only has $300 budget which is why I bought these rims. I am reaching out to the guy but hes not responding. I just recently got into the world of cars December and wonder what does +23, +35 offset?
02-25-2020, 08:58 AM | #13 |
Drives: 2017 Camaro 2.0T, 91 Miata Join Date: Jan 2020
I have 19x10.5 et22 and 305s up front. There's less than 5mm room between the rim/tire and the strut, but I've yet to hear it rub. 20x10 et23 shouldn't be an issue.
02-25-2020, 10:14 AM | #14 |
See that's what I was told by my friend! the issue only occurred on the right front wheel where it rubbed once I turned the wheel to reverse. I am trying to get the brand of the rims I purchased.
Tags |
camaro, camaro rims, spacers |
