12-18-2016, 06:37 PM | #1 |
Too much is never enough!
Drives: AGP TT SS [COTW] 4/20/15 Join Date: Feb 2014
Crankshaft reccomendations
Thinking of stroking my engine. I have forged pistons and rods already, I left the stock crank in when I built it last time. The car is going under the knife again in 6 to 8 weeks and I am debating on just swapping the stock crank for a forged Callies.
Questions are what crank should I go with, even if its not a Callies, and where do you recommend I buy one? I will most likely source it through my builder as well.
AGP TT kit, 54/57 Forged rotating assembly, Custom grind cam... Dual nozzle meth, ID850's, Livernois dual fuel pumps, ECS BAP, 25% UDP, 3 inch Magnaflow catback with X pipe, Mantic 9000 clutch, DSS 1000hp axles, DSS aluminum driveshaft, ZL1 rear end, solid subframe bushings, HE differential offset bushings, BMR Trailing arm, BMR toe rods, Lingenfelter LNC-2000,SJM Line Lock. 747 whp 714wtq
Build thread http://www.camaro5.com/forums/showth...55#post8107855 |
12-18-2016, 06:42 PM | #2 |
Drives: 2SS/RS L99 BLACK Join Date: Apr 2010
The Callies Compstar is a good crank at a reasonable price.
12-18-2016, 06:49 PM | #3 |
Drives: 2009 ZR1 Join Date: May 2010
Will a stroker crank work with your existing pistons?
12-18-2016, 07:18 PM | #4 |
Part number? Purchasing source?
I don't see why not....But I don't know to answer that question.
12-18-2016, 07:46 PM | #5 |
If you're going with a 4" stroke AP031N-CS58, always verify part # when ordering your application may be different than mine. Summit, Jegg's, they are pretty readily available.
12-18-2016, 07:47 PM | #6 |
Yes, I am going with a 4 inch stroke. Thanks for the help.
12-18-2016, 07:52 PM | #7 |
Typically, when using a stroker crank you run the risk of the piston skirts hitting the crank thus the need for stroker pistons. I believe the Compstar's crank is relieved for additional clearance but every combination is different so it should be checked.
12-18-2016, 08:36 PM | #8 |
Drives: Black 2SS RS w/White Stripes Join Date: Mar 2011
Has anyone tried the somewhat recently released Dart Billet crank? It seems to be priced similarly to the forged cranks on the market.
2010 2SS/RS "ChriSStine":
Pat G Custom Turbo CamMotion Camshaft | AGP TT BB Garrett 62/65's | AGP/Fore Triple Pumps | ID1700X Injectors | Alky Control Twin Nozzle Meth | Custom 3" Exhaust | 3.27 gear set w/ Tru Trac | McLeod Twin RXT | Barton Short Throw Shifter | 6th Gen ZL1 Wheels | BMR 1.4" drop springs | Pfadt rear trailing arms & tie rods | Installed by Me & Tuned by Pat G |
12-18-2016, 11:04 PM | #9 |
Callies Compstar Great Value I'm not going over a 1000 on spray so it was plenty. If would have went more builder would have put a Dragonslayer in it.
'11 IBM 2SS/RS Built and Tuned by Vengeance Racing Vengeance PCM
Vengeance Racing Mast Black Label LS7 Headed 416 ProCharger Stage II D1X Race ,Monster Triple,Alky Control Meth Inj, Forgestar F14 Drag Version and a bunch of other blah blah blah.838/688 at 12lbs Street Friendly |
12-19-2016, 06:48 AM | #10 |
H-Town Camaro Club
Drives: 2010 ABM 1SS/RS, Red 85 Z28 Join Date: Feb 2013
You can't put in a stroker crank with the stock length rods and pistons. The piston pin location is different for each individual stroke, so you have to match up the piston for the right rod length and crank stroke.
AGP Twin Turbo, RPS Triple Carbon Clutch, ZL1 Diff with 3.73 gears and Kooks 3" Stainless Steel Exhaust with X Crossover, Kooks Stainless Steel Mufflers, Go Fast Bits EBC, AEM Methanol injection and AEM gauges UEGO and Fuel pressure, Livernois's dual fuel pump, KB Boost a Pump, AUS 1000cc injectors, Full BMR suspension with Koni shocks, JDP Color Changing Halos, Color Changing Scanner Light Bar and Rockford Fosgate T Series Amp's Kicker L7 Sub's.
Build Thread: http://www.camaro5.com/forums/showthread.php?t=400372 |
12-19-2016, 09:25 AM | #11 | |
Considering everything, I guess I'll just spend the money elsewhere. Thanks everyone for responding.
12-21-2016, 10:59 PM | #12 |
2010 transformer
Drives: 2010 ss camaro Join Date: Nov 2014
A few guys I know have had failures with compstar. Above 900 rwhp
2010 transformer, vertical doors, 315nt05 rears, pedders supercar coilovers, hotchkis sway bars, links, adjustable, toe bars, bmr poly cradle bushings, 1le control arms, bmr tunnel brace, bmr subframe connectors. Cam 227/239-623-620@114 Mast medium bore heads, sw 1 7/8 headers, cat delete, x pipe, 3" dynomax true duals, fuel rails, fast 102 intake and NW 102 throttle body, catch can, rotofab cai, shifter, raptor custom shift light. Dss drive shaft, 3.91 gears. 492 rwhp
12-22-2016, 05:37 AM | #13 |
Drives: Anything I want Join Date: Oct 2008
Callies#1 in our book
We have never had a bad compstar or dragonslayer crank or magnum crank
In fact we have never had bad anything from Callie's. |
12-22-2016, 07:20 AM | #14 |
Drives: 2006 Z06 Join Date: Oct 2010
I've only had 2 issues with Calles. The 8 months it took to get a crank, and the complete pain in the ass to pin it for the blower because it is so damn hard. Other than that, absolutely top notch stuff.
Nick
Corvette Z06 -1200ish rwhp |
