Old 09-18-2019, 11:02 PM   #1
rickybobby
Drives: BMW M3, ZL1 1LE
Brake fluid leaking at the track
I flushed my brake fluid with dot4 before my first track day. I am experienced at doing car maintenance and properly torqued all bleeder screws. I had a nice firm pedal and drove the car for a week in the street and everything felt great.
At my first track day at Laguna I noticed some brake fluid weeping out of some of the bleeder screws. I tightened them and it seemed to fix the problem. I had a bit of a soft pedal so I re-bled them when I got home just to be safe. I also cleaned and dried all fluid just to be sure.
Fast forward to track day #2 and #3 I am still getting some weeping out of one caliper. When I looked at it tonight I think it is because there is some red powder coating overspray on the bleeder screws from the factory that are preventing me from getting a good seal.
Has anyone experienced brake fluid leaking at the track? Also, can anyone confirm if their bleeder screws are red like mine?
I have to decide if in want to remove and clean my bleeder screws or just get new ones. Or take it to the dealer for warranty.
rickybobby is offline   Reply With Quote
Old 09-18-2019, 11:19 PM   #2
Try2paz
Drives: 1967 Nova
No leaking at the track... I’ve heard of guys melting the seals in the calipers from running track pads and the brakes getting to hot.
I’d replace the bleeder and flush the system
Try2paz is offline   Reply With Quote
Old 09-18-2019, 11:23 PM   #3
R3ctivision
1LE Convert
R3ctivision's Avatar
Drives: 2018 ZLE
This happens to me at every track day when brakes get hot after I've done a bleed or flush. Never had a performance issue or a failure. I believe that when you flush or bleed the brakes, there is a little bit of brake fluid left behind inside the bleeder nipple. When you get the brakes really hot, I think that fluid maybe expands and then seeps out onto the caliper. Only once did my bleeder screw need to be tightened at the track.
I think it's safe to make sure they are tight before you go on track, and check after every session when the brakes have cooled a bit. If you see any seepage, wipe it up IMO. I often do up to four track days before the next bleed or flush, and usually the seepage does not recur until the next time I've opened the screw.
2018 Camaro ZL1 1LE (Red Hot)
2002 BMW Spec E46 race car (Lizard Green)
Previous cars:
- 2018 Miata RF GT (Machine Gray/Auburn)
- 2017 Camaro 1SS 1LE (Summit White)
- 2008 BMW 135i (Montego Blue)
- 1996 BMW 328i (Arctic Silver)
R3ctivision is offline   Reply With Quote
Old 09-19-2019, 06:43 AM   #4
kaamacat
Drives: 2018 ZL1/1LE Red
Just checked mine...and yes a small bit of overspray on my bleeder upper threads. (After thinking about it, I guess better to have the bleeder in there and attempt a full cover vs leaving out when doing the color application).
As for weeping. None BUT, when I bleed/flush I so take a small corner of paper towel and put in the bleeder hole to get that small excess out so when the caliper heats up it will not overflow onto the caliper. (small amount that it is)
BobR
2018 ZL1 1LE (Red) - New Dec 2017
2015 ViperGT (Gunmetal w/Red stripes)
2013 ZR1 Anniversary
2014 ZL1 - BrightYellow, 6sp
2011 Porsche GT3RS - White w/red graphics
2009 Porsche C2S
2001 Ferrari 360
kaamacat is offline   Reply With Quote
Old 09-19-2019, 07:54 AM   #5
PROMETHEUS
PROMETHEUS's Avatar
I use to get seepage on my corvette during track days. I assumed it was the brake fluid expanding from the heat. Never had any issues with the brakes on the track.
Old 09-19-2019, 09:03 AM   #6
gotswap
gotswap's Avatar
Drives: 2019 ZL1 Crush
Swap em out for speed bleeders, I do this for every vehicle when I bleed the brakes.
gotswap is offline   Reply With Quote
Old 09-19-2019, 01:14 PM   #7
rickybobby
Thanks for all the responses. I thoroughly cleaned and dried all of the bleeder screws after the 1st track day bleed, so I’m fairly confident that it isn’t residual fluid. Especially since I got a soft pedal.
Since I’m down to only one leaking caliper, I’ll just remove and clean the 2 bleeders in question and call it a day. Maybe my car was built on a Friday as I also had a bad exhaust weld (covered under warranty).
Old 06-18-2020, 01:24 AM   #8
Rams01
Rams01's Avatar
Drives: 2018 ZL1, 2001 Z28 1LE
Not to bump an old thread but on my first track day June 8th I experienced this as well after having the dealer flush out the factory dot 3 for brembo H64 Dot 4 fluid. Pedal felt good on the street and stopped well and did great for the first 2 20 minute sessions at MSR 3.1 but on the 3rd session of the day the temps were around 100F and the car was getting sluggish and brakes were fading and oil temps were up so cut it short 15 minutes in when the brakes began to "let go" or so i assumed.
Drive the car home and throw it in park and brake fluid low light came on and of course the disabling of all stabilitrak, TCS, etc. Check the driver side rear and sure enough, fluid all over the wheel well which I thought was residual fluid left from the GM tech bleeding the system and leaving a mess.
Was down half a pint of fluid, had a buddy push the pedal and sure enough, fluid spraying out of the top bleeder screw which explained the crappy pedal feel and poor performance.
Any idea what went wrong or if its flat out user error and something I should have had on my checklist of things to check after each session? I'm still new to track racing so not sure if this is a common issue but some quick research shows that I am not the only person that's experienced this.
Rams01 is offline   Reply With Quote
Old 06-18-2020, 11:05 AM   #9
rickybobby
This sounds to me like the dealer simply didn’t tighten the bleeder screw enough.
In my case, I think it was the powder coating and wearing in if my bleeder screw threads that caused my initial leaking. I cleaned all my bleeder screws and don’t have an issue any more. That is a bit of residual fluid running down after I bleed no matter how well I clean it up but, no performance or fluid loss like you are describing.
Old 06-18-2020, 06:05 PM   #10
Stephen12ZL1
Stephen12ZL1's Avatar
Drives: '21 ZLE A10
You should definitely check the bleeders after the bleeding procedure because you need a little extra torque...not crazy just a little. After heat cycling (because of the expansion/contraction of metals) sometimes a little bit of loosening occurs. Always check your bleeders after the calipers have cooled or before the next track day. Mine dribble a bit...no worries.
Old 06-19-2020, 10:16 AM   #11
Whitespeed
Drives: 2018 1SS 1LE & 1973 Datsun 240Z
It also can take a few cycles of loosening and tightening for the bleeder and the seat to conform to each other and seal properly on new calipers.
Nigel
Whitespeed is offline   Reply With Quote
Old 06-21-2020, 12:00 AM   #12
AZ_1LE
Drives: 2019 ZL1 1LE
Yea, just a loose bleeder. There's kind of a fine line between tightening it enough, and too much. On the race cars in the Pirelli World Challenge, Brembo and StopTech gave us pretty precise torque values to tighten them to, and we did this before every session the cars went out on track. The heating and cooling will work them loose if they're not torqued right. I wish I knew the tq value for ours.
Also, we always sprayed the bleeder out with brake cleaner every time we bled the brakes. Will be a little rougher on our calipers since they're painted and some brake parts cleaner will etch the finish.
Old: 2017 SS 1LE
Old: 2017 ZL1
Current: 2019 ZL1 1LE
AZ_1LE is offline   Reply With Quote
Old 06-13-2022, 05:26 PM   #13
Grifka_Garage
Grifka_Garage's Avatar
Drives: 2021 Camaro ZL1 1LE
17-20 Nm for the bleeders
Grifka_Garage is offline   Reply With Quote
Old 06-13-2022, 08:36 PM   #14
SFV1LE
Drives: 2018 Hyper Blue ZL1 1LE
On a different but related topic, I did notice my fluid reservoir cap would "sweat" and dribble some fluid during track days using Motul 660, which is supposed to be great DOT 4 racing fluid. After I switched to Brembo Racing and Castrol SRF this stopped completely, I assume the Motul 660 was boiling over and the others do not.
Also, I recommend everyone switch to braided SS lines.
SFV1LE is offline   Reply With Quote
