07-29-2019, 06:40 PM | #1 |
Drives: 2011 1SS RS Synergy Join Date: Aug 2010
CLOSED: ZL1 Differential 3.73
Searching for a ZL1 3.73 differential to set aside for a fall/winter project.
CLOSED- found what I needed. Ebay and Facebook were better resources for these parts. Many leads. Last edited by R3VoLuTioN; 08-22-2019 at 04:24 PM. |
07-31-2019, 09:13 AM | #2 |
Drives: 2014 Camaro SS Red Hot Join Date: Jul 2019
Following
08-04-2019, 08:40 PM | #3 |
08-04-2019, 08:56 PM | #4 |
If not a bother, and to to hijack the thread, but why you decided to go with 3.73 over 3.91?
Thanks Sent from my iPhone using Tapatalk |
08-04-2019, 10:10 PM | #5 | |
There's nothing to hijack here, glad to answer! The 3.91 differential may not reliably handle the amount of power I have. From what I understand it's basically identical to the stock SS m6 3.45 but with a different ratio. The ZL1 3.73 is heavy duty and beefed up for the power. It's much more substantial. |
08-04-2019, 11:25 PM | #6 | |
Got it. Thank you for your reply! And good luck! Sent from my iPhone using Tapatalk |
08-10-2019, 06:15 PM | #7 |
Still looking
08-13-2019, 03:58 PM | #8 |
Drives: 80 Z28 - 93 Z28 - 14 Camaro SS-RS Join Date: Sep 2016
Again not to hijack, but it is my understanding no one makes gears for the ZL1 differential and the only choices are 3.23 and 3.73. I could be wrong, but this is what I saw when I was looking for the same thing for my car. You need Diff half shafts driveshaft something on the end of the transmission oil block off lines as the ZL1 has a cooler. I am sure I am missing some small stuff but this is the list as I remember it.
08-13-2019, 10:22 PM | #9 | |
