01-11-2018, 08:03 AM | #1 |
Drives: '18 ZL1 & '17 2500HD Midnight Ed Join Date: Nov 2014
Firewall/shock tower brace removal
Trying to do some engine bay customization while the car is sitting for the winter... Has anyone removed the braces between the firewall and shock towers? I'd like to get them hydro dipped with a carbon fiber pattern. I removed all 4 nuts/bolts to get the braces loose, but can't rotate them or move them enough to clear the stud on the firewall. Is there an easy way to get them out without causing too many problems?
2018 Camaro ZL1 - Garnet Red Tintcoat[/B]
- Order Placed@ dealership 8/12/2017 - 1100 8/21/2017 - 3100 8/23/2017 (TPW 9/11) - 3400 8/25/2017 - 4300 9/11/2017 (VIN available) - 4200 9/15/2017 - 4200 9/20/2017 (on train near North Platte, NE) - 4200 9/22/2017 - 4200 9/23/2017 (car in town) - 5000 9/25/2017 - 6000 9/26/2017 (Finally in our garage!) |
01-11-2018, 08:20 AM | #2 |
Drives: 2018 zl1,A10,16 GLC300 Join Date: Jul 2017
No help, but I am wondering about this myself. I was thinking of doing something with them to dress up the engine bay. Looks like they should just unbolt an pop out.
2018 ABM,A10
Kooks 2” headers no cats, NW 103 Tb, Kong ported blower with 2.31 pully, Elite E2x catch can, Cordes under hood expansion tank, Flowmaster axle back, Rotofab dry filter,Mustang Dyno # 647whp/674wtq. |
01-11-2018, 08:35 AM | #3 |
That was my thoughts too, but easier said than done. The bracket at the back bolt in the pictures won't allow it to rotate enough to remove it. And the approximately 1 inch stud that you have to clear at the firewall doesn't help.
01-11-2018, 11:39 AM | #4 | |
Drives: 2017 A10 ZL1 Join Date: Apr 2013
2017 Camaro ZL1 Coupe Black |A10|PDR|NAV|
10-31-2018, 08:14 AM | #5 |
Drives: 2018 zl1 1LE Join Date: Mar 2017
Reviving a dead thread. Has anyone figured out how to remove these braces?
2018 ZL1 1LE
2021 GLS63 AMG 2005 SRT4 2017 Ram 1500 |
10-31-2018, 06:35 PM | #6 |
2018 Garnet Red ZL1 conve
Drives: 2013 & 2018 ZL1 vert Join Date: May 2009
Engine braces
I sure would like to know also, I was going to try and paint mine carbon flash along with some other engine parts. They look easy but I thought about that on several other items and they are a pain in the ass! Such as the HMI swap out for the front camera mod.
Build Thread: 2018 ZL1 Vert Purchased (Overpar73)
09-14-2021, 08:33 AM | #7 |
Drives: 2021 Chevrolet Camaro ZL1 Join Date: Apr 2021
Figure I'd revive this dead horse. Anyone have any luck?
09-14-2021, 09:04 AM | #8 |
Limitless Imagination
Drives: 2018 ZL1 & 2022 Hayabusa Join Date: Dec 2016
Sub'ing as well, got me interested in doing something to them as well.
2018 Camaro ZL1 - Black
- OEM Options: A10, Exposed Carbon, PVR, Nav, No Sunroof - Lightly Tinted GM Dark Tails, DD Side Markers, Morimoto 5000k, 100% LED - RotoFab Dry, Forgestar CF5V (ZLE Spec), Eibach Pro, AeroForce Interceptor, GT4 Tow Hook - Carbon Fiber (Satin): Radio, Shifter, Steering Wheel Controls, Shifter Top, AC Vents, Side Mirrors & Shark Fin 2022 Suzuki Hayabusa - Brilliant White Pearl & Shocker Yellow Wheels - +4 Arm, 240 OEM Wheel, Brock's CT (Ti) Exhaust, 1.25" drop, etc... |
09-14-2021, 09:26 AM | #9 |
Drives: Camaro ZL1 Join Date: May 2020
Cut it out with a saw.
09-14-2021, 09:52 AM | #10 |
And JB weld back together to reinstall
09-14-2021, 10:24 AM | #11 |
Angle grinder is faster, plus you get to enjoy a nice sparkle + smoke show
09-15-2021, 06:26 AM | #12 |
Drives: 19' ZL1 A10, w/pdr Join Date: Sep 2014
It's not that hard. Remove the plastic cowl first, then you will see all the nuts and bolts that need removed. You have to take the 10mm bolts and nuts off the cowl plenum #9. Then pry the plenum just enough on each end up enough to clear the center mount. The plenum has adhesive holding it in place. You need to just raise the ends enough to clear mounts.
BTR Stg II cam w/ 38% fuel lobe, ARH 2" headers into 3" w/cats, AWE Touring, Kong X port, Weapon X triple ht exchangers, NW 103, Rotofab big gulp, DSX lowside, TCM tune, BMR Lockout, Mustang dyno 720 rwhp, 634 rwtq on 93 pump.
09-15-2021, 11:38 AM | #13 |
Appreciate it.....I havent tried clearing the plenum part yet. I need to remove the trim anyways for other stuff. Have you been with the WeaponX mods? I'm originally from Ohio (Lebanon then Wilmington area) so thought about bringing it back to them in Cincinnati.
09-15-2021, 12:13 PM | #14 | |
When you remove the 10 mm plenum nuts and bolts, then you can get the ends to lift enough to clear that middle mount. There is one 10mm nut under the washer arm, forget it, don't need it removed anyway. Seems to be less adhesive on the plenum ends for maybe this reason. No mods have been done by WeaponX. I am putting on those cosmetic parts first while staying under warranty, then probably their 900 pkg. Will see about next year maybe.
