10-17-2018, 01:11 PM | #29 |
Drives: 2017 Camaro 2SS Nightfall Gray vert Join Date: Jan 2018
I couldn't agree more. I posted on another thread the results from 12psi, but really if you balance the gains from boost with the stress on the engine...it really does make the original setup such a great play.
85mm 8psi - 700whp 80mm 10psi - 730whp 75mm 12psi - 760whp 70mm 14-15psi - 800whp (projected with mix of e85 and ms109) I am about to test on the 14-15psi to see where that puts us, but I am leaning toward dropping back to the original setup 8psi on the 85mm pulley for the street. Most likely I will stick with the 8-10psi on the street and then will bump to the 12-15 for the strip. The right decision might be tied to the type of tires I have at the time and the type of event.
Magnuson Heartbeat SC - Tuned by JRE Racing 776whp/745wtq (12psi) 2018 Corvette Z06 vert- Black To be tuned by JRE Racing TBD performance |
10-17-2018, 09:54 PM | #30 |
Drives: 2015 C7 Z06 M7 Join Date: Dec 2012
Nice work Russ and Ted!
When I ran the 9.93 in our Camaro with the stock LT1 I used the 75mm pulley - 70mm with your mods = |
10-17-2018, 10:11 PM | #31 | |
We were hoping to get out and run with Greg's drag pack, but we are about out of time in St. Louis. I ordered the 70mm pulley today. Do you happen to know which belt I need for the 70mm?
10-17-2018, 10:29 PM | #32 |
I can look at mine to see what it is.
