09-03-2020, 06:59 PM | #1 |
Drives: 2019 ZL1 m6 Join Date: Jan 2019
AXDSPX-GM30 for 2019 ZL1 vert (bose)?
Getting ready to jump down the rabbit hole and start upgrading my audio - local audio shop recommended this and it is new to me. Looks like it should work...can anybody give me a thumbs up or thumbs down?
https://axxessinterfaces.com/product/AXDSPX-GM30 |
09-04-2020, 05:30 AM | #2 |
The description says it's designed for non-amplified models...
2021 2SS A10 - Summit White - NPP - MRC - Adrenaline Red Interior Pkg - Black Appearance Pkg - Ground Effect Pkg - Suede Steering Wheel and shifter - Red Calipers - Carbon Flash Wheels w black lug nuts - DD Tinted Side Markers - Hero Tinted Rear Reflectors - Redline Fender Badges - 20% Tint
Audio System Build Log ----------------------------------------------------------- 2014 Z/28 Summit White - sold 2020 2010 2SS/RS Summit White - sold 2014 |
09-04-2020, 09:10 AM | #3 |
Drives: Chevrolet SS 1LE Join Date: Oct 2019
If this is true, it's the first factory interface I know of for non-amplified 2019+ Camaros. That's pretty exciting. I'd call and ask first though, because their website is a little difficult to decipher on this.
Matt Miller
2020 SS 1LE |
09-04-2020, 10:03 AM | #4 |
Ok, so just a convo with the tech support guy at Metra (for the above device) and it works ONLY with non-Bose 8" (with or without Nav) systems. It will NOT work with a Bose system.
Good news for non-Bose guys but not so much for me...
09-05-2020, 09:00 AM | #5 |
Thanks for the input - looks like a hard pass for me. Back to the drawing board. Right now I'm really looking to add a shallow mount sub (maybe 2 depending on size) and an amp (or 2?) to run everything - with room to further upgrade down the road if/when I get the urge. I am scouring the boards trying to learn as much as I can, and am a little overwhelmed at how many pieces are needed to maintain factory features/usability. I'd love to do the work myself as I'm sure it would be far cheaper, however compatibility with 2019s is making me nervous. Doesn't seem to be a lot out there at the moment. :/
09-05-2020, 10:29 AM | #6 | |
Drives: 2020 SS1LE Shadow Gray Metallic Join Date: Feb 2018
09-05-2020, 11:58 AM | #7 |
With Bose, why not use the NAV TV ZEN AVB-GM? It gives you control over everything.
Matt Miller
2020 SS 1LE |
09-05-2020, 12:11 PM | #8 |
I've got a convertible so I'm not sure I'm working with the same speaker setup as the coupe (which is also why I am eyeing the shallow mount subs for underneath the folding top). The NAV TV ZEN AVB-GM does look like the magic bullet, but I've read some conflicting (and confusing to me) reports. I'm just a little trigger shy due to the expense. Local shop has mentioned a couple different similar products but after searching this forum (which is such an awesome resource) and researching on my own, almost everything else I am being suggested is for 2018s and older. My 2019 won't play nice with their recommendations.
I do have the Bose - but with the 'vert, no sub. Thus started my quest for better audio. While I am a novice to car audio, I am still toying with the idea of doing things myself if I can find pieces I know will work. The plug and play element is extremely appealing to me - the less cutting/splicing/drilling etc. I have to do, the better. At least for now. |
09-05-2020, 02:33 PM | #9 | |
Here is the link to the Posi connectors and a video on how to install them https://www.crutchfield.com/p_669PP6...onnectors.html |
09-07-2020, 02:40 AM | #10 | |
Drives: Fast if no one's looking Join Date: Aug 2019
09-07-2020, 10:27 PM | #11 |
Drives: 2023 2SS Convertible Join Date: May 2009
I wish somebody would make a plug and play sub box for verts. It seems like there is room on the driver's side - if you go around some electronics - for at least an 8" sub, maybe a 10".
-Geoff
09-09-2020, 08:18 AM | #12 |
Drives: 2018 Camaro 2SS Join Date: Feb 2019
Its not in a vert but I installed the Kicker 46hs10 powered 10 inch sub. It was very easy to install. I put mine in the trunk for now and it sound pretty good. Surprisingly good sound in a small package.
