Old 07-25-2020, 02:25 PM   #1
klslelrl
Drives: Chevrolet Camaro
Question What can happen in transmission fill plug if not put back
What can happen if you transmission fill plug is left off and you drive your car with raining and water on roads? 2012 Camaro
klslelrl is offline   Reply With Quote
Old 08-13-2020, 10:18 PM   #2
Rams01
Rams01's Avatar
Drives: 2018 ZL1, 2001 Z28 1LE
IDK sounds like it would slosh out of the hole to a point where the fluid is low or if you drove through a giant puddle now filled with water.
What happens is you **** it up.
Rams01 is offline   Reply With Quote
Old 10-18-2020, 03:18 PM   #3
R3ctivision
1LE Convert
R3ctivision's Avatar
Drives: 2018 ZLE
I'd suggest immediately stop driving the car, order a new plug, drain whatever fluid may still be in there, and flush it once with fresh fluid to make sure it's not contaminated with other stuff, then fill AGAIN with fresh fluid and close it up. Then I'd move on with my life and hope it doesn't break
2018 Camaro ZL1 1LE (Red Hot)
2002 BMW Spec E46 race car (Lizard Green)
Previous cars:
- 2018 Miata RF GT (Machine Gray/Auburn)
- 2017 Camaro 1SS 1LE (Summit White)
- 2008 BMW 135i (Montego Blue)
- 1996 BMW 328i (Arctic Silver)
R3ctivision is offline   Reply With Quote
Old 10-18-2020, 04:37 PM   #4
Mark114
Mark114's Avatar
Drives: 2016 2SS Convertible
In your previous post you mentioned that the dealer forgot to install the fill plug during the previous visit. As others have posted your car’s transmission probably leaked fluid during the drive home and is probably low now. It is possible that some water splashed up into the transmission. Certainly not a good situation. Low fluid and water will both contribute to shifting problems. It’s good that the dealer is going to have it towed back to the shop for repairs. I would expect the dealer to completely flush and fill the transmission with fresh fluid and replace the plug. I would try to get them to replace the transmission filter too. If the the transmission doesn’t work normally after that then hopefully the dealer will make good on their mistake and continue to diagnose and resolve problems until it is right.
Old 10-18-2020, 04:54 PM   #5
supersportss
Drives: 2019 SS
unicorns and rainbows fly out your butt.
supersportss is offline   Reply With Quote
Old 10-18-2020, 06:02 PM   #6
thescreensavers
thescreensavers's Avatar
Drives: SW 1SS 1LE / Jeep XJ
Needs a complete drain and fill now
thescreensavers is offline   Reply With Quote
