Old 05-25-2020, 03:52 PM   #1
V1LE SS
V1LE SS's Avatar
Drives: 2018 1LE SS
Metal "flapping" sound after 2" header install (video included)
If you listen to the video with a decent pair of headphones you can easily hear the sound.
About a day or two after my 2" header install on my 18 ss 1le, if you drive with the windows up no music on and ac off or on low you can hear what is almost like a rattle type sound that follows you up and down through the rpm range....nothing seems to be hitting the frame, heat shields or on the headers. Just trying to get some input on if others have had a similar sound.
V1LE SS is offline   Reply With Quote
Old 05-25-2020, 04:13 PM   #2
avalonandl
avalonandl's Avatar
Drives: 2019 ZL-1
More likey a clamp connecter etc.
The injectors are nowhere near the headers.
Also look at your plug wires, no contact? And your steering shaft....
Old 05-25-2020, 04:18 PM   #3
V1LE SS
V1LE SS's Avatar
Drives: 2018 1LE SS
Headers are currently welded onto the midpipes, no leaks or movement there, all clamps back are good, sound is coming from right behind the cluster towards the driverside firewall area of the motor...steering shaft does make contact only on hard right turns, can't imagine it can move that much just driving straight down a highway. I'm thinking something is reverberating through the headers thats allowing me to hear it inside the cabin.
18' MBM 1SS 1LE, PDR
2" Speed Engineering headers
Lethalgarage flex fuel sensor
LT2 non ported Intake manifold
Rotofab-CAI
mishimoto catchcan
Old 05-28-2020, 09:52 PM   #4
avalonandl
avalonandl's Avatar
Drives: 2019 ZL-1
Sounds like steering shaft is contacting headers and telegraphing the sound thru... maybe..
