Homepage Garage Wiki Register Members List Social Groups Calendar Search Today's Posts Mark Forums Read
Old 09-21-2016, 05:55 PM   #1
Capisce
Drives: 2016 2SS Camaro
Too much oil?
Having a slight panic attack over here. Despite all the reccomendations to check oil levels during break in, I just checked it today for the first time. Seems I'm sitting high and must have been for minimum 1,000 miles. The only time the car was touched was for this pit stop thing the dealer does to top off fluids and check cars maybe a month after you buy them. They credit your account with $50 towards any service in the future just for going.. so I figure why not.
I can't imagine the car coming with too much oil from the factory so I have to assume I was incorrectly topped off during the pit stop. I think I threw out the paperwork so I can't see right now if any note was made.
Pit stop had to be at like 300 miles and I'm at 1500 now. Oil is above hatch marks after car sat for 2 hours. It's hard to see exactly how much higher but it looks to be at maybe the top of the piece that has the hatch marks in it. Right before it becomes the braided wire. Maybe even a little into the wire.
How much damage could have been caused? How would I know? How much extra oil does it take to cause damage?
2SS - Summit White - MRC - NPP
Capisce is offline   Reply With Quote
Old 09-21-2016, 06:09 PM   #2
cellsafemode
cellsafemode's Avatar
Drives: 2016 Camaro 1LT
I take it that since it's hard to see, that the oil is still newish clean. You shouldn't have anything to worry about. Just drain a bit.
overfilling is bad because oil will not be able to fully drain back into the pan and so may lead to some oil not getting filtered. If you're still rocking clean oil, not much dirt/metal has had a chance to build up in the oil to matter.
Old 09-21-2016, 06:26 PM   #3
MiamiBlueCamaro
MiamiBlueCamaro's Avatar
Drives: Gen 6 Camaro RS
From the "manual":
Old 09-21-2016, 06:30 PM   #4
Drags1998
Drives: 15 SilveradoLTZ,162SSVert 19BLAZER
Don't worry about it, Just Drive it, and ENJOY IT!!!!
Drags1998 is offline   Reply With Quote
Old 09-21-2016, 06:45 PM   #5
Glen e
Retired from Car mfrs....
Glen e's Avatar
Drives: 2LT RS/HR-V
General rule of thumb: you're don't have to worry about too much oil until it spits the dipstick. Meaning oil coming out of the dipstick.
But I assume we learned our lesson here?
LESSON :Anytime a dealer goes near your car, before you leave the service lane, walk around the car, check all the gauges/pressures and the check oil.
Old 09-21-2016, 06:50 PM   #6
Capisce
Thanks glen, that eased my mind. And yep, never again
Old 09-21-2016, 07:18 PM   #7
JFM-jr
JFM-jr's Avatar
Some dealers put 6 qrts others put over 10 smh
2016 Hyper Blue 2SS A8,NPP,Moonroof
Pray ported factory intake manifold Ported TB
Rotofab
ARH 1 7/8 longtubes hi flow cats AFM deleted E85
11.0@124.9
11.65@118.8 pump gas,stock tune/exhaust
New combo: Pray Performance Heads/cam
MSD intake manifold and Circle D 3C
554/491 on E85 all work & tuning done by Pray
JFM-jr is offline   Reply With Quote
Old 09-24-2016, 09:37 PM   #8
10redrocket
Drives: 2SS Camaro LS3
The problem with too much oil is cavitation.
This is caused by the crankshaft coming into contact with the oil and churning it causing air to be mixed into the oil. This results in small air bubbles being mixed in with the oil and loss of lubrication. This will definitely damage an engine. Just how bad depends on how much cavitation you have. Most likely damaged are the bearings.
Your probably ok if your not hearing any knocking. However, if it's starts to knock say in the next couple thousand miles you know why.
The only real way to know if it effected the engine is to drop the pan and pull the caps.
RECEIVED 5/22/09 - 2SS, SIM with CGM stripes, Black Leather, Polished 20's, Sunroof, LS3.
Past Rides: 69 Camaro RS Small Block
67 Chevelle SS Big Block
05 Cobalt SS Supercharged
07 Cobalt SS Supercharged
10 Camaro 2SS LS3
Soon: 18 Camaro 2SS 1LE
10redrocket is offline   Reply With Quote
Old 09-24-2016, 10:25 PM   #9
Cruiter
Cruiter's Avatar
Drives: 2016 H/R 2SS Convertible 6.2/Auto
The 2SS has the same LT1 V8 engine my 2014 C7 Z51 Vette had except that it was a dry sump that had more oil capacity. If you're talking the 2SS the engine holds 10 qts of oil and it's listed in the back of your manual.
Cruiter is offline   Reply With Quote
Copyright ©2000 - 2020, vBulletin Solutions, Inc.
