Old 06-26-2022, 02:05 PM   #1
North of You
North of You's Avatar
Drives: 2007 Honda Civic
Anti siphoning valve?
So,
My gas in the tank is getting a bit old so… instead of running the tank empty, I thought I would be smart and just siphon most of it out. The hose never did get as far down in the tank to reach the gas, and now there seems to be a little valve just below the flapper on the tank filler that wont let go of my hose, and im not able to move it with a screw driver.
Help!
North of You is offline   Reply With Quote
Old 06-26-2022, 02:56 PM   #2
Gunkk
Thank you Al Oppenheiser!
Gunkk's Avatar
Why not use the fuel pump to drain the tank?
Old 06-26-2022, 04:02 PM   #3
North of You
I thought this would be easier…..
Old 06-26-2022, 04:21 PM   #4
6spdhyperblue
Drives: 6th gen
What are the steps to do this?
Do you jump it in the fusebox or relay or use hptuners?
Where do you disconnect the line?
‘22 SS 1LE M6 Summit White - RF, Flexfuel, LT2 intake, 95mm tb, ATI udp, VT ramair, catchcan, Adam’s Graphine 9yr
‘16 SS M6 bolton on DR 11.0@126+ (Sold)
Old 06-26-2022, 04:22 PM   #5
6spdhyperblue
Drives: 6th gen
Originally Posted by North of You View Post
So,
Help!
I wonder if there’s a way to lube the hose. The dryness of the fuel is maybe making it grip?
Old 06-26-2022, 04:28 PM   #6
North of You
Nope, there is a secondary flapper valve that is pinching the tube closed and it wont budge open even with the help of a screwdriver.
Old 06-26-2022, 06:08 PM   #7
LiqTenExp
LiqTenExp's Avatar
Drives: 2017 ZL1
cut up and bend straight a clothes hanger (non-painted) and see if you can send it down to jiggle it loose?
2017 Camaro ZL1 Coupe M6 (847whp on Dynojet)
Old 06-26-2022, 06:14 PM   #8
Mark114
Mark114's Avatar
Drives: 2016 2SS Convertible
Here is a thread with the HP Tuners command to activate fuel pump.
https://www.camaro6.com/forums/showthread.php?t=510721
Old 06-26-2022, 06:19 PM   #9
6spdhyperblue
Drives: 6th gen
I tried after that post and my pump didn’t turn on?
Old 06-26-2022, 08:10 PM   #10
Alan47717
Drives: 2022 1LT RS 2.0t/6spd
So,
Help!
My car came with a small funnel designed to open both valves in case the owner runs out of gas and needs to add more from a can. It should be available from a dealer. If your hose is small enough the funnel may be able to slide over it and allow you to remove it.
Alan47717 is offline   Reply With Quote
Old 06-27-2022, 12:18 AM   #11
2SS Capt
2020 Shadow Gray 2SS
2SS Capt's Avatar
Your hose may be snagged on the secondary valve, while pushing the screwdriver in push the hose in a slight bit and see if the valve releases...
2020 Shadow Gray Metallic 2SS - A10, NPP, MRC, Red Calipers, Carbon Flash Wheels, Black Camaro Fender Badge, Footwell Lighting
Added after delivery: - GMP CAI, GMP Black Strut Tower Brace, SS Logo Armrest, Black Fuel Door, Stainless Sport Pedal Kit, SS Wheel Caps, Black Lugs/Locks, GM Body Color Splash Guards, DD Smoked LED Markers, Smoked Rear Reflectors, Mishimoto Catch Can, Xpel PPF - Full Front, SunTek 35% Tint, CeramicPro coating
On the left, my "toy" ride, on the right, my "work" ride, a Gulfstream G600. One's top speed is 180 Mph, the other, 610 Mph...
Old 06-27-2022, 12:39 AM   #12
North of You
I tried that and that hose wont move in our out. Its that second flapper valve about an inch behind the main flapper valve, that just wont budge open.
Copyright ©2000 - 2022, vBulletin Solutions, Inc.
