This is my first post so I will try to not make it long-winded. 2017 2ss with 30k miles, no mods, original owner. LTFT for both banks is reading -8 to -18 on idle. STFT bounce from 0 to 2.6. It's an intermittent rough idle with random misfires: in 5 minutes cylinder 2 misfired 52 times, and a few other cylinders under 5 times where after a short drive cylinder 5 then misfired 32 times and #8 15 times in 5 minutes. I recorded the diagnostic tools readings (2 tools under $200) if someone wants to know more but here are some points: Fuel pressure 47, fuel rail pressure 550-650, MAF 0.6-0.7 lb/m, MAP 8 "HG, Oxygen sensor readings/voltage and cat monitors came back good on mode 6 data.
6 months ago I had a rough idle and backfired on a cold start-up for 20 seconds, LTFT never went below -8 at the time, so I changed all spark plugs and spark plug wires with just OEM, new fuel injector for cylinder #7 because the car threw that cylinder code, and changed PCV value since there was some oil in the intake manifold. The problem went away for a few months and now my idle is getting rough again with the problems listed above. Any input is much appreciated since I am totally lost right now. |
![]() Drives: 21 ZL1 Join Date: Feb 2022
Its not running rich. The car is pulling fuel so it doesn't run rich. If it was pegged at -25 and you were still running like shit, then yes at that point its actually running rich. What you are seeing is normal for the stock tune. The tune is commanding this rich condition and the fuel trims are doing their job pulling it back to keep it in stoich. In WOT openloop, none of that matters.
#3 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 6th gen Join Date: Aug 2013
What fuel do u put in it
‘22 SS 1LE M6 Summit White - RF, Flexfuel, LT2 intake, 95mm tb, ATI udp, VT ramair, catchcan, Adam’s Graphine 9yr
‘16 SS M6 bolton on DR 11.0@126+ (Sold) |
![]() Drives: Not yet…. Join Date: Apr 2022
Fuel is garbage or it needs to be run hard to clean the plugs. LT1/2/4 can load up plugs fairly easily if they are idled and babied a lot.
Strictly Chevron premium. There’s only a few other gas stations here. I will try stretching it’s legs tomorrow. Might just have to take a road trip I guess. That would make sense given I don’t drive it during the winter and I haven’t gone on a road trip for a couple years. (I used a fuel preservative for winter and fuel system cleaner beginning this year, but the cleaner didn’t help.)
#7 | |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 19 Chevrolet Camaro 2SS 1LE Shock Join Date: Apr 2020
Not sure if telling the OP to drive the car hard without exactly knowing the issue is a good idea. If the spark plug is loaded then I would at least pull the ones out of the offending cylinders to check. There are also the usual culprits like air filter and MAF sensors, which are easy to check and address, so I would start there.
Current:
2019 Chevrolet Camaro 2SS 1LE M6 Shock GM Performance Intake and that's it, because driver mods before car mods Past: 2009 Mazda RX-8 GT M6 Velocity Red Mica (Sold) 2015 Chevrolet Corvette Z51 2LT M7 Velocity Yellow Tintcoat (Flood totaled) |
#8 | |
#9 |
Try chevron Techron
#10 |
#11 |
I thought the manual says only chevron Techron? Others could have things that can cause damage. Not sure
#12 |
Redline Si-1 is good stuff. No trouble running that once in a while.
So I took a look last night at my OBD2 data and while I was hit idling, my MAF was reading 0.8~0.85 lb/min. Keep in mind that I live at near or even a little below sea level and I have the GM Performance air intake(with the calibration done). A MAF reading low should cause a lean condition, though, but it could be something you could look into.
Current:
#13 |
I took a 300 mile trip yesterday and the car does idle better, but it isn’t perfect yet. I will just keep driving it until something else happens.
#14 | |
My stock stock ZL1 on 93 sits between -15% and -8%. That's not bad. Its just set rich in the tune from the factory. During closed loop, the car runs fine. But in open loop, this is why some can pick up mph by running e30 on a stock car/stock tune. They are able to lean it out safely and pick up HP in open loop(WOT) because the car doesnt use the fuel trims. |
Thread Tools | |
