06-03-2022, 01:22 PM | #1 | |
Drives: chevrolet camaro Join Date: Feb 2021
water leaks into engine at car wash
how can this much water not affect the engine..this is scary...any advice?
06-03-2022, 02:09 PM | #2 |
Drives: 2020 Callaway Camaro SC630 Join Date: Feb 2020
Drain holes are already there and then engine heat.
2020 Callaway Camaro SC630 - MN6 1SS Satin Steel Gray
2019 Callaway Corvette SC757 - MN7 1LZ Elkhart Lake Blue |
06-03-2022, 02:20 PM | #3 |
Mid-engine lyfe, I guess
06-03-2022, 02:21 PM | #4 |
Drives: 2017 Camaro SS, 2011 Corvette GS Join Date: Feb 2019
Car is designed to be driven in the rain and go through car washes. Drain holes, weather pack connectors, etc. all protect and seal the engine and electrical systems from water.
So nothing at all to worry about. |
06-03-2022, 02:27 PM | #5 |
Drives: Chevy Camaro Join Date: Apr 2020
Classic case of looking for a problem that doesn’t exist. A camaro ss has a giant hole in the top of the hood, open front grill, and a wide open bottom. I am sure you would see worse results in a camaro.
06-03-2022, 02:28 PM | #6 |
Well - that was almost unbelievable! The amount of water that flowed in there would convince me that someday it would get where you don’t want it (like inside of electrical connections). I know that GM designed and tested the car to handle this but I’d be tempted to only hand wash that car from now on.
06-03-2022, 02:43 PM | #7 |
Drives: 2020 LT1 M6 Join Date: Jan 2016
Anyone who puts a c8 through an automatic car wash deserves whatever issue/damage could potentially happen. Either wash it yourself or take it to a high end hand wash carwash/detailing business.
06-03-2022, 03:34 PM | #8 | |
Rayvan
Drives: 2018 1SS1LE, Silver Ice Metallic Join Date: Dec 2018
Electrical connections are all sealed these days. GM has been using sealed connectors since the early eighties. |
06-03-2022, 03:46 PM | #9 |
Long hauler
All I see is a free engine bay wash whenever you wash the exterior
06-03-2022, 08:11 PM | #10 | |
Drives: 2018 1SS 1LE & 1973 Datsun 240Z Join Date: Sep 2015
It was a touchless wash. In other words no spinning brushes contacting the car and the car was probably stationary the whole time (no tracks). What's the big deal? Nigel |
06-03-2022, 08:26 PM | #11 |
Anything can happen on one of those units, they are not meant to exclusively contour to dimensions of a low profile mid engine exotic car. These systems are designed to universally clean trucks, suv's, vans, sedans and econoboxes, most of the time doing a piss poor job in the process due to so much variances in dimensions. The hand wash upscale detailers provide a value and reassuarnce which I feel is absolutely worth the upcharge cleaning exotics, sports, and high end models, c8 included.
06-03-2022, 08:52 PM | #12 |
Ditto! I agree completely with this.
06-03-2022, 09:39 PM | #13 | |
The touchless washes I use spray water and soap over the car using a moving gantry that follows the profile of the car while the car is stationary. It even sprays the underside of the car as you drive in, which you can't get with a hand wash. Again, no spinning brushes, or anything for that matter other than soap and water, touch the car ever. Unless the car is really filthy, this does the job perfectly well the majority of the time, particularly if the car has been ceramic coated. Drive in, rinse, soap, rinse, blow dry and drive out, towel dry door jams etc. Is it the absolutely best wash you can get? Of course not. But this idea that it's somehow going to mangle your car or leave a layer of grime all over it is far fetched. Nigel Last edited by Whitespeed; 06-03-2022 at 10:00 PM. |
06-03-2022, 10:04 PM | #14 |
Hail to the King baby!
Drives: '19 XT4 2.0T & '22 VW Atlas 2.0T Join Date: Dec 2008
Yeah, OP, use that same camera and drive in a heavy rain. This isn't a trunk it’s an engine compartment. It will get wet and what the video shows is normal and expected.
That being said, and mentioned earlier, if the engine isnt ingesting water it’s a non issue. Late launch change for C6 Z06 due to car wash…….cough………cough
