11-13-2021, 10:08 PM | #1 |
Drives: 2016 Camaro 2SS Join Date: Jun 2016
Alignment after new tires necessary?
Hi all, will be going from stock 2ss wheels/tires to MRR017s with 285/30/20 front, 305/30/20 rear. My car tracks straight. Should I get an alignment with the new wheels/tires? Just don't like dealers/shops working on my car unless I have to.
11-15-2021, 07:32 AM | #2 |
Drives: 23 ZL1 A10 Rapid Blue Join Date: Aug 2020
Factory alignment can be poor and usually an alignment check is "free" and the only charge is if its out. Mount/balance of tires and alignment are really different things for a tech I'd really check out that part of the shop you choose. Some want to put it in the "green" (inspec) and call it good enough and you might want more care used there like getting the camber dialed in etc etc
11-15-2021, 03:07 PM | #3 |
Thanks. I'm getting tires/wheels from PK Auto, so planning to put them on myself. I haven't had any issues, but the tread's getting low on the original tires. So I'm wondering if I can just put the new setup on and be done, or if I should take it in to be aligned.
11-16-2021, 10:00 AM | #4 |
Drives: 2017 Blue Camaro 1SS 1LE with PDR Join Date: Sep 2018
If the tread wore evenly on the previous set of tires (inside vs. middle vs. outside) and the car doesn't pull to one side when driving straight on a flat road (and while braking) then there's no reason to spend money on an alignment.
11-16-2021, 11:33 AM | #5 |
Thanks. That's what I was hoping!
11-16-2021, 12:09 PM | #6 |
You should absolutely be able to bolt them right on without needing an alignment. I concur with Post #4
12-08-2021, 05:56 PM | #7 |
Drives: 2016 Camaro Join Date: Oct 2017
My Camaro drove straight but the camber was off on the right rear wheel. That burned up the tire after 8,000 miles. If you have the GOODYEAR EAGLE F1 SUPERCAR 3 tires you might find they are a little softer than the UTQG rating of 220.
2024 Chevrolet 3500HD Z71, LTZ, 4x4, 6.6 ltr. L5P long-bed.
2016 Camaro 2SS Six-speed, Hotchkis sway bars, Eibach .750" drop springs, Mamo throttle body, E85, BMR stuff. 2006 Quicksilver 6-speed GTO ERL LS3-430, All-Pro 285cc heads, 262/273 .758/.742 116+3 cam, Sheet-metal Intake, 70lb Siemens injectors, SLP, GMM Ripshifter, QA1 Coil-overs front and rear, nylon suspension bushings, Hotchkis, RPM Trans, SPEC twin clutch, SpinTech, Kooks 1 7/8 -2.0", BMR drive train, Kaaz 3.91, Lingenfelter CAI, Baer brakes, mini-tubs, E85. |
12-08-2021, 06:10 PM | #8 |
i would definately get one done but i also get around 2-3 alignments a year due to me tracking my car !
Thread Tools | |
