Old 10-29-2021, 11:43 AM   #1
LeoDirt
LeoDirt's Avatar
Drives: 2019 Camaro SS
Electric water pump
Been working on
This with a buddy of mine. What do you guys think? I’m using an
Older style lt1 electric water pump from meziere. Had to change the water pump blades to turn the fins the opposite direction and had to make an adapter plate. Should be able to test it out in a week or so.
LeoDirt is offline   Reply With Quote
Old 10-29-2021, 11:46 AM   #2
MP3BOOSTED
MP3BOOSTED's Avatar
Drives: 2017 Camaro SS 1LE (F1A-94 FBO H/C)
impressive
Performance Mods: F1A-94, DSX Flex Fuel Kit, MSD Spark Plug Wires, KOOK 2" off road headers, MBRP Race catback exhaust, Pray Performance Custom Boost Cam, Rocker Arm Trunion Upgrade Kit, 7.850" Hardened Chromemoly Length Pushrods and Johnson Racing 2110R Lifters, TSP CNC'd Heads, Ported MSD intake manifold, 103mm Katech Throttle body, Forged Pistons/Rods, RPM Meth kit, DSX Aux Fuel system, AEM Failsafe and banks gauge, LT4 HPFP, LT4 injectors, BMR motor mounts, Hurst Short Throw, Manley SS exhaust valves
Videos of my car? Check here: https://www.youtube.com/channel/UCNi...Qy1OL4NVGlPogw
MP3BOOSTED is offline   Reply With Quote
Old 10-29-2021, 11:54 AM   #3
LeoDirt
LeoDirt's Avatar
Originally Posted by MP3BOOSTED View Post
impressive
Thanks.
Old 11-15-2021, 06:24 PM   #4
CreeperRS
CreeperRS's Avatar
Drives: 20’ Chevrolet Camaro 2SS 1LE
So, how’s this set up holding up? Any progress? News?
CreeperRS is offline   Reply With Quote
Old 11-15-2021, 06:53 PM   #5
Trochoidal
Drives: 2017 Camaro 2SS A8
Nice project. Did you add a fillet at the bottom of those fins that isn’t clear in your picture?
I don’t know your background, but if that’s a sharp corner at the bottom I’d change it to have a fillet. Is that ABS or Nylon 6 material?
Old 12-03-2021, 08:35 PM   #6
LeoDirt
LeoDirt's Avatar
Parts are currently being made in aluminum. All the test parts were made in plastic. Will hopefully be able to test this here soon. Need to get the holidays out of the way first.
Old 12-03-2021, 08:37 PM   #7
LeoDirt
LeoDirt's Avatar
those parts are all abs plastic. In the process of having them all made in aluminum cureently.
Old 12-04-2021, 05:15 PM   #8
RUQWIKR
RUQWIKR's Avatar
Drives: 1LEs
From my drag racing days, you can use adapters to go to LSx (Gen 3/ 4) style water pump including the various eletric Meziere versions with or without a built main pulley. If not needing to turn a supercharger belt or A/C belt, you can space the generator rearward and run off the 4-groove A/C belt section on the stock or an underdrive ATI balancer. Think you're doing cool work, just throwing the above out as typing outloud point.
https://dirtydingo.com/shop/pages.php?pID=32&CDpath=3
RUQWIKR is offline   Reply With Quote
Old 12-08-2021, 01:00 PM   #9
LeoDirt
LeoDirt's Avatar
that setup you have there will work with that intake manifold. When you use the lt1 msd 103mm style intake manifold you run into clearance issues. Also you have the vaccum box attached to the back of the water pump I still wanna use. I have a brand new meziere ls3 style water from my vette. I tried it but in the end for my application i thought this would be the better route to go.
Old 12-08-2021, 04:15 PM   #10
RUQWIKR
RUQWIKR's Avatar
Drives: 1LEs
Those are pics off its website not my car. I was just thinking outloud how I would go about it, not saying your approach is wrong. You can also use a remote EMP / Stewart pump (up to 55GPM) to AN fittings off the adapter block. We've done that as well on cars especially non-heater ones. Good luck either way.
Old 12-09-2021, 04:26 PM   #11
Trochoidal
Nice! Are you having these made at a machine shop?
Old 12-11-2021, 10:45 AM   #12
LeoDirt
LeoDirt's Avatar
yes i am
Old 01-09-2022, 01:40 PM   #13
LeoDirt
LeoDirt's Avatar
Update on the pump. It’s almost done. Hope to test it out here soon.
Old 01-09-2022, 01:41 PM   #14
LeoDirt
LeoDirt's Avatar
Pics.
