Old 07-24-2021, 11:01 AM   #1
FoundNemo
Drives: 2019 ZL1
Custom exhaust setup installing next week!
My buddy finally has all the parts in for his custom exhaust setup. Custom fabbed 3" 304 stainless resonated cat deletes for track use (3" kooks ball flanges/2-bolt flanges, vibrant 3" x 6" race mufflers, vibrant 304 stainless saddle-seat o2 bungs), ARP stainless header bolts and ARP stainless collector bolts/nuts/washers, CSP 2" jet hot coated longtubes, G-Sport GESI 850hp per bank Gen 2 cats for street use, dual Vibrant 304 stainless 3" x 6" turboflex sections, dual 3" x 22" Magnaflow resonators for the OEM x pipe, Corsa Sport axle back with 3" crimp delete. The goal is zero rasp regardless of cats/no cats and no drone, with all the glorious sound.
Vids coming soon!
FoundNemo is offline   Reply With Quote
Old 07-24-2021, 11:09 AM   #2
GTO_Gregory
GTO_Gregory's Avatar
Drives: 2016 Camaro
What kind of emissions and catalytic tests are there in Georgia? I'm thinking you plan on swapping the converters in for the test and then back out afterwards.
2024 Chevrolet 3500HD Z71, LTZ, 4x4, 6.6 ltr. L5P long-bed.
2016 Camaro 2SS Six-speed, Hotchkis sway bars, Eibach .750" drop springs, Mamo throttle body, E85, BMR stuff.
2006 Quicksilver 6-speed GTO ERL LS3-430, All-Pro 285cc heads, 262/273 .758/.742 116+3 cam, Sheet-metal Intake, 70lb Siemens injectors, SLP, GMM Ripshifter, QA1 Coil-overs front and rear, nylon suspension bushings, Hotchkis, RPM Trans, SPEC twin clutch, SpinTech, Kooks 1 7/8 -2.0", BMR drive train, Kaaz 3.91, Lingenfelter CAI, Baer brakes, mini-tubs, E85.
GTO_Gregory is offline   Reply With Quote
Old 07-24-2021, 11:18 AM   #3
FoundNemo
Drives: 2019 ZL1
Not my car, buddy's car, but no he will run full cats as required for street use. The cats are EPA certified as well at G-Sport for these specific ones and the front and rear o2's will be fully active. If he road courses it, he will use the deletes for those runs only. If you were going to swap in/out for emissions only, no reason to buy such a robust cat imo.
Old 07-25-2021, 04:56 PM   #4
jvandy50
jvandy50's Avatar
Drives: 18 ZL1-1LE, 10 JKU
Looking forward to hearing this. Corsa does an excellent job regarding drone
jvandy50 is offline   Reply With Quote
Old 07-26-2021, 05:53 AM   #5
FoundNemo
Drives: 2019 ZL1
Cheers. He is stoked and me too frankly. Current setup has zero drone when I rode with him.
