06-01-2021, 08:47 AM | #1 |
Red Bull
Drives: 2017 Chevy ZL1 Join Date: Dec 2020
Tire size help
Will the 315/35 20 nitto 555r 2s fit on the stock ZL1 rims with rubbing? Or what about the 305/35 20 nitto 555r 2s on ZL1? I am needing some new rear tires any advice would be great!
06-01-2021, 09:14 AM | #2 |
Drives: A10 ZL1 Join Date: Mar 2018
Having both, I would go with Toyo888r’s
06-01-2021, 09:40 AM | #3 |
Well, not if OP isn't a fan of monster truck style tire whine, these Toyos are very noisy.
OP, why 315/35/20 and not 315/30/20? These are a whopping 1.5" taller than the OEM size, what is the advantage you're after?
06-01-2021, 09:58 AM | #4 |
Drives: 2019 ZL-1, Shadow Gray, Sold Join Date: Jan 2019
Yes, the 315 will fit on the 11" wheel. However,
The 305/35 is 1.2" taller than OEM The 315/35 is 1.5" taller and .4" wider than the OEM. I suspect at least the 315 will rub the top of the fender or liner. The width is not an issue, but I would still relocate the wiring harness on the driver's side. |
06-01-2021, 09:59 AM | #5 |
06-01-2021, 10:28 AM | #6 |
Drives: 23 ZL1 A10 Rapid Blue Join Date: Aug 2020
315/35 will rub and not sure if a simple harness move will do it as noted that quite a difference without a spacer, perhaps. Too unsure if the height is over the limit that the ABS/Stabilitrak can cope with
Thread Tools | |
