02-16-2021, 11:48 AM | #1 |
Drives: 2019 ZL1 1LE Join Date: Feb 2017
Anyone in the San Antonio/Austin area with a 4x4?
EDIT: Power just came back on!
Old: 2017 SS 1LE
Old: 2017 ZL1 Current: 2019 ZL1 1LE Last edited by AZ_1LE; 02-16-2021 at 12:01 PM. |
02-16-2021, 12:35 PM | #2 |
Drives: 2021 Camaro LT1 Conv Join Date: Oct 2016
02-16-2021, 01:01 PM | #3 |
Drives: '17 2SS convertible'20 Yukon Denali Join Date: Nov 2011
Here in Cedar Park, northwest of Austin, we started getting the rolling blackouts Sunday night/Monday morning. They said 40 to 45 minutes but they have ranged from an hour up to 5 hours. About three times daily. Can't do anything important on the computer since the power will go off without warning. Come on spring. Damn you, groundhog.
Richard
2017 2SS SIM convertible, A8, NPP, MRC, 56R wheels, GM CAI, Diode Dynamics Side Markers Delivered: 08/15/2016 #TeamBeckyD |
02-16-2021, 01:33 PM | #4 |
Yea, my mom has been home alone since it went out on Sunday, and then the water stopped early monday morning. My dad's been out of town on a work trip and can't get back because of cancelled flights and no rental cars available.
Pool plumbing all exploded around the pump and filter, irrigation system is toast, hose bibs are questionable which is the main concern (if they burst in the wall, that's gonna suuuuck to fix). The neighbors helped her shut off the water valve at the street so they can make sure there aren't any crazy bad leaks when it comes back on. And the power did come back on a little bit ago, but the heat pump was making a helluva racket and so they shut it back off. But the neighbors also helped her get the fireplace going and brought some firewood. It's still only 40 degrees in the house. They also are taking buckets of slushy water from the pool back to their houses so they can flush toilets. But the roads in their neighborhood are the issue. There's only one road in/out from the main highway and it's fairly steep in places. Unless they lay down some salt and/or sand or gravel, I don't see how anything other than a 4x4 with chains is going to get in there before it melts in a few days. I was hoping someone could bring them some food or water or something, but it'll probably be near impossible. I'm already planning on taking some days off work coming up to fly out there and help my dad fix everything. It's a mess.
Old: 2017 SS 1LE
Old: 2017 ZL1 Current: 2019 ZL1 1LE |
02-16-2021, 02:15 PM | #5 |
Drives: 2020 2SS Vert/M6/F250 SD Join Date: Jan 2021
Is it true you have a bunch of windmills producing power for you and the ice shut them down?
02-16-2021, 02:38 PM | #6 |
Drives: 15 SilveradoLTZ,162SSVert BlazerRS Join Date: Dec 2015
I TRULY feel for You Guys, Living in Maine we see this ALL TO OFTEN!!!! Good Luck and make sure to check on some of your older Neighbors!!!
02-16-2021, 05:38 PM | #7 |
Drives: 022 C8 Z51 Red Mist HTC Join Date: Feb 2021
02-16-2021, 06:09 PM | #8 |
Thats what I was thinking. I think the biggest issue is the totally irregular situation. When was the last time anything like this hit that far south?
But it does potentially indicate that the new green deals are more fragile than previous power generation. I imagine the windmills in the northern states are regularly exposed to consistently lower temps. I wonder if they would use different components where the cold is not expected. Im all for clean air and inteligent power generation. But when you hear the reality of someones mom stuck up an ice covered road without heat... water or food.. Thats really disturbing. And if its something that could have been avoided by intelligent technology as opposed to what could be politically motivated decision making.. That would piss me off.
02-16-2021, 06:50 PM | #9 |
Drives: 2016 Camaro Join Date: Oct 2017
I'm in the Fort Hood area and the base has been closed all week and the end of last week. The power out times are getting shorter each day. I have a 3200/4000 Watt Harbor Freight generator for difficult times. My 4x4 2500HD helped me get around with ease.
The weather is historical for Texas. Texas probably needs some nuclear power plants. The state voted for coal plants because they are cheap to build.
2024 Chevrolet 3500HD Z71, LTZ, 4x4, 6.6 ltr. L5P long-bed.
2016 Camaro 2SS Six-speed, Hotchkis sway bars, Eibach .750" drop springs, Mamo throttle body, E85, BMR stuff. 2006 Quicksilver 6-speed GTO ERL LS3-430, All-Pro 285cc heads, 262/273 .758/.742 116+3 cam, Sheet-metal Intake, 70lb Siemens injectors, SLP, GMM Ripshifter, QA1 Coil-overs front and rear, nylon suspension bushings, Hotchkis, RPM Trans, SPEC twin clutch, SpinTech, Kooks 1 7/8 -2.0", BMR drive train, Kaaz 3.91, Lingenfelter CAI, Baer brakes, mini-tubs, E85. Last edited by GTO_Gregory; 02-16-2021 at 07:10 PM. Reason: Add Info. |
02-16-2021, 07:25 PM | #10 |
Yea generators are common in the NE. And given the condition of the country these days, food for at least a month. Ability to filter water.
The last 4 cars Ive had for my wife have been all wheel drive. Ive had a 4x4 truck since the 80's. The sheep dogs have to be able to get through. But I have come across a young man in a 4x4 who were terrified to go down a slight hill in the snow. People who are going 5 mph and who then high beam me because I go around them. It seems people around here are becoming increasingly incompetent. I can see by your location your likely more adaptable than average.
02-16-2021, 10:31 PM | #11 | |
Dumb Ass Deluxe
Drives: A Tricked Out Mountain Bike Join Date: Jun 2019
Turn them on and the freon boils off and takes all the oil with it and your running pistons/cranks/bearings without oil and/or liquids are getting into the cylinder(s) and getting compressed. When that happens you get that racket. If you have an "emergency heat" switch on the thermostat, you can try to switch it over to that. It will work IF: You actually have backup electric heaters It is wired up for emergency heat After 12hrs of continuous power, if equipped with crankcase heaters (which generally heatpumpsl. are), you can fire it up and everything should be normal. If not, turn the heat on and let it run for 1 minute and shut it off for 5 several times. That will stir up the oil/freon, mechanically warm the compressor and help get the liquid freon out of the oil. DO NOT run the compressor if it is making that noise, unless you want to buy new compressors and/or units. PM me if you need any more help.
02-17-2021, 12:23 AM | #12 |
D3RPZILLA
I'm in new braunfels tx... I had bad timing and pulled apart my old 2000 explorer awd a few weeks ago lol
Sent from my GM1917 using Tapatalk
Website: z1lla.com | YouTube: youtube.d3rpzilla.com YouTube Playlists: Performance Mods | Interior & Exterior Mods | Other Mods |
02-17-2021, 08:24 AM | #13 |
Drives: Camaro SS 1LE Join Date: Aug 2018
02-17-2021, 04:58 PM | #14 | |
The other problem is the water used for steam generation froze. All this green new deal stuff is already causing problems even with the fraction of these policies in effect. We are being driven off a cliff. Price per bbl of crude November 2020... $40 Price per bbl today... $60 Doesnt take long to frig everything up.
