05-20-2017, 10:13 AM | #1 |
Drives: '19 SS 1LE/'19 Rubicon/'20 AT4 Join Date: May 2015
1LE specific ramps & lug socket
I noticed two things with me 1LE...
1) Problem: even with some boards in front of my Rhino ramps I was able to push the ramp with the splitter then drop the car down, cracking the splitter. Classic. Solutions: take splitter off, repair, put back on; get a new splitter; take it off and leave if off. Future prevention: Race Ramps. But which size/length do you guys use? there are 56" and 67" and there are one and two piece versions. probably a life-long investment so thinking of springing for the 67" which also offers 2" of height (10" instead of 8" once car seated). 1) problem: even with a long socket, my torque wrench is rubbing against my tire (very close to wheel). solutions: simple problem, so simple solution I hope.. extension? although I haven't seen any before. any other tricks? just be careful? thanks! Matt |
05-20-2017, 10:16 AM | #2 |
Retired from Car mfrs....
I use 4" extension....no prob......
05-22-2017, 12:51 PM | #3 |
Drives: 2017 Camaro SS 1LE Summit White Join Date: Jan 2017
I bought a Titan Tools 22mm socket from Amazon.
https://www.amazon.com/Titan-Tools-2...tan+tools+22mm I'm trying to figure out a way to modify my Rhino ramps. I was thinking of using some 2x10 to get the car up and onto the ramps. |
05-22-2017, 02:17 PM | #4 | |
マスタング = 遅い
Drives: 2017 Chevrolet Camaro SS 1LE Join Date: Aug 2015
05-22-2017, 08:20 PM | #5 |
Drives: 2017 1SS 1LE (Krypton Green) Join Date: Mar 2017
I went with the 72" 2-Piece Race Ramps and they are plenty could have gone shorter but got a better deal on ththe longer ones. Defiantly get the 2-piece though. So much easier to work under the car without ramps in the way.
05-22-2017, 08:48 PM | #6 | |
Drives: '18 JLU Rubicon, '19 Golf R Join Date: Jun 2011
Doing it again, now that the quick jack is available I wouldn't buy the Race Ramps again as they are pretty expensive for what they are, in comparison. |
05-22-2017, 09:57 PM | #7 | |
the ramps are pricey but they will last a lifetime hopefully.... and there just isn't much out there to compete. |
05-22-2017, 09:58 PM | #8 |
Ordered a set of it the 60-some inch 2pc set... more portable and easier to get under like u said!
05-22-2017, 10:00 PM | #9 | |
05-22-2017, 10:17 PM | #10 |
Drives: 2023 CT5 Blackwing Join Date: Sep 2016
56" Race Ramps in 2-piece.
22mm with a 3" extension.
2017 HBM SS 1LE
Sold 2023 Wave Metallic CT5-V Blackwing M6 |
05-22-2017, 10:24 PM | #11 | |
Yes, they will last a very long time if you take care of them. They are super light as well since they are made of foam. For a portable ramp I would probably use my Rhino ramps + two 2x4s and a couple rubber mouse pads to keep the ramps from sliding. The mouse pads worked before I got the Race Ramps and Quick Jack on my garage floor that had a slick epoxy. |
05-23-2017, 05:50 AM | #12 | |
Drives: '17 SS/1LE/PDR Join Date: Feb 2017
PRAY ported MSD/TB : ROTOFAB/dry : DSX flex fuel : HPA Stage 3 : ARH catted long system/oem NPP : RSR harness bar : RSD : FSO1 : MPS4S 305F/325R
05-23-2017, 06:57 AM | #13 |
Drives: 2017 1LE Hyper Blue Metallic Join Date: Mar 2017
How are you guys tightening the lugs back to 140 ft/lbs? I looked at air impact wrenches which seem great for removal, but overpowering for tightening?
05-23-2017, 07:50 AM | #14 |
Drives: '98 Pontiac Trans Am Join Date: May 2016
Torque wrench, I wouldn't worry about buying an expensive one if all your doing is lug nuts. I have a Craftsman, which I trust, but I do a lot of repairs and rebuilds so I sprung a little more money for the name brand. On the high end would be your MAC, Matco, SnapOn, etc. but you could spend a lot of $ on those.
2017 1LE Camaro Hopeful
1998 Trans Am M6, Bolt Ons (Daily Driver) 2005 Eddie Bauer Expedition (Family Vehicle) 2007 Z51 Corvette M6 (Salvage Project Car) 1987 Trans Am 350tpi A4 RIP |
