01-11-2017, 05:45 AM | #1 |
Drives: 2017 Camaro SS 1LE Join Date: Dec 2016
Daily driving tires for stock 1LE wheels
I just bought my 1LE and I really like it but i drive 57 miles to work and back every day.
Im looking at those big soft steam rollers wondering how long is that going to last! What other tires last longer and dont cost an arm and a leg My usual go to tire is a Nitto555 but the usually last about 25k. But are dont perform like the supercar tire. Anyone tried NT05 how long do they last. I woul like to get a tire that can make 20k a year thoughts?
2020 ZL1 1LE Crush
2017 SS 1LE Hyper Blue sold :( 1995 Mustang GT 427ci Road race car Youtube: Steelankles https://youtube.com/c/steelankles |
01-11-2017, 07:22 AM | #2 |
Drives: E92 BMW M3 Join Date: Oct 2012
Michelin Pilot Super Sport. You gotta pay to play though. You cant get soft, big performance tires with good tread wear for cheap.
J-Rod Built and Matt@FSP Tuned |
01-11-2017, 07:51 AM | #3 | |
Drives: 2023 CT5 Blackwing Join Date: Sep 2016
2017 HBM SS 1LE
Sold 2023 Wave Metallic CT5-V Blackwing M6 |
01-11-2017, 08:53 AM | #4 |
Drives: 17 SS 1LE Join Date: Dec 2015
01-11-2017, 08:58 AM | #5 |
Drives: 1LEs Join Date: May 2009
Tomorrow or Friday, I'll have MPSS's I got from TireRack mounted on another set of stock wheels. Continental DW's are not a bad choice either. Both are WAY better than the Nitto 555's, but, at a price. You have to click on the tire sizes individually on the website as they don't show up under a ZL1 and SS 1LE was not on the drop down menu, at least when I ordered. Plus, there are at least two versions of each tire size with different compounds and tread depths to choose from.
01-11-2017, 09:48 AM | #6 | |
Drives: New : 2017 SS 1LE Old: 2012 TTRS M6 Join Date: Oct 2015
. https://www.wheelwell.com/profile/56...ed9c3a/garage/ . . Project 1LE Wraith: http://www.camaro6.com/forums/showthread.php?t=474068 |
01-11-2017, 01:26 PM | #7 |
pretty sure thats what i had on my c7 was mpss runflats
lasted 11k with 1 trackday. replaced it with 555s tw was 300 wasnt even close to performance level though Sounds like nt05 would last even less than that.
2020 ZL1 1LE Crush
01-11-2017, 07:37 PM | #8 |
01-12-2017, 06:24 AM | #9 | |
Sounds like tires are going to be a frequent purchase for you maybe with as aggressive as it seems you drive. Good luck in your search though, I hope you find something that works for you.
01-12-2017, 11:25 AM | #10 |
Drives: 2014 2SS/RS 1LE Join Date: May 2013
From my research the MPSS will not give you significantly more milage than the stock tires. (assuming the Supercar 3's get similar mileage to the Goodyear Supercar G:2s on my 5th Gen) One of the big issues you guys will have with your 6th Gen 1LE's is that you won't be able to rotate a staggered tire setup and that will negatively affect the mileage you will be able to get from a set of tires. In addition the MPSS (Max Performance Summer) will not perform as well as the Supercar 3's or any of the other Extreme Performance Summer tires available, namely the Bridgestone RE-71r's or the Hankook RS3's and soon to be released RS4's. (I don't think anything else will fit) If you switch to MPSS you will be getting about the same milage in a more expensive tire and lower performance than the stock Goodyears or similar Extreme Summer tire.
If your only goal is to increase milage then your best bet is to forget any of the Summer tires and go with a square setup with Ultra High Performance All-Season tires. The Michelin Pilot Sport A/S 3+ should fit front and back with 285/30R20's or potentially Bridgestone Potenza RE970AS Pole Position, or Continental Extremecontact DWS in 285/30R20 either of the last two could fit with a slight stretch on the back wheels. Rotation would require dismounting of the tires though. These are also cheaper by at least $100 per tire than the MPSS or any of the other Summer tires discussed. You will have significantly less handling performance but you gain a LOT of mileage and save money per tire to boot so its a good tradeoff. There are probably other sizes in the Ultra High Performance All-Season category that will fit your stock wheels but I didn't take the time to look up all possibilities. TLDR: MPSS will cost more, give you similar mileage and lower performance than the stock Goodyear Supercar 3's. Go with Ultra High Performance All-Season tires to save money and get better mileage.
01-12-2017, 04:35 PM | #11 | |
01-12-2017, 04:41 PM | #12 |
If available (not sure of sizes they have) and wanting an all season high performance tire instead, Continental DWS06 or Michelin AS3+ are good choices. Have the 06's on wife's car and my lowly Cruze Eco.
01-12-2017, 05:05 PM | #13 |
"M1SS1LE"
Drives: 2017 SS 1LE Join Date: Dec 2015
This!!! buy the Pilot Sport 4's in march and run the 295/30R20's all around on a 20X10 wheel. Then you can also rotate to maximize the mileage from them.
MJK3888 Instagram Link
01-13-2017, 03:37 AM | #14 |
Are you doing this? I imagine that might be tight in the front...
