dave@hennessey
Old 11-09-2017, 02:46 PM   #1
513Speed1LE
513Speed1LE's Avatar
Drives: 2014 2SS/RS 1LE
What aftermarket mufflers/exhaust do you have?
Hey guys, I'm going to install an exhaust system on my 2014 1LE. I'm not sure how dual tip catbacks will look with the 1LE facia, I'd hate to buy an exhaust and have the tip be offset either outward or inward leaving an obvious gap in the facia. So, for those of you who have dual tips, do you experience this?
For those of you that have quad tips, what catback did you choose and why? I'm having a tough time finding quad tip catbacks for v8's in the 2014 year range. I've seen several quad tip setups for the ZL1, but I'm not sure if there is compatibility between the two cars.
This could go into the bolt ons section, but I figured that this was more of a 1LE specific question.
Thanks.
2014 2SS/RS 1LE Blacked Out
513Speed1LE is offline   Reply With Quote
Old 11-09-2017, 04:14 PM   #2
Stormcloak
slower than you
Stormcloak's Avatar
Drives: 2012 C6 Z06
I have the Stainless Works retro catbacks, which you can get with either single or dual tip options The tips can be set to your liking in terms of how far out or tucked they are.
Stormcloak is offline   Reply With Quote
Old 11-09-2017, 05:20 PM   #3
The Hunter
The Hunter's Avatar
Drives: 2015 Summit White 2SS/RS 1LE
I got the TSP headers and love them. Went in super easy without any problems from underneath the car.
CAI Intake, BTR Stage 3 cam, LS Bushing Trunnion Upgrade, Chromoly Pushrods, .660" Lift BTR Spring Kit, TSP LT Headers, Cat Delete, Mild 2 Wild Exhaust Switch
The Hunter is offline   Reply With Quote
Old 11-09-2017, 06:36 PM   #4
Clarkstar
Clarkstar's Avatar
Drives: 2013 1SS 1LE
I had the npp quad tips, traded them for duals and swapped the diffuser. I like the look of the duals better, more old school.
2013 1le- Katech 416 short block, TSP custom grind cam, LOD intake, cnc heads by F.ED., Nick William's 102mm T.B., CORN fed, Pedders coilovers. Performance street alingnment by Justin at Lake Country Alignment and dyno tune by Late Model Throttle.
603 h.p. 495 ft lbs tq.
Clarkstar is offline   Reply With Quote
Old 11-09-2017, 10:25 PM   #5
Texas_RS
Texas_RS's Avatar
Drives: 2013 1LE/SS
Running no exhaust, with dual tips though. Just replaced factory h with a magnaflow true x-pipe and deleted Factory mufflers
Current mods: Stainless Power Long Tube Headers,Cat Delete,CAI Cold Air Intake,Vitesse throttle controller, Muffler/Resonator Delete w/dual tips. ADM Performance Tuned,BMR 1.25 lowering springs,R1 Concept Slotted/Dimpled Rotors.
Texas_RS is offline   Reply With Quote
Old 11-10-2017, 06:53 AM   #6
jeff657756
Drives: 2014 SS 1LE
I believe most of the ZL1 systems fit the 1LEs. I have the hooker quad tip 3in straight back system.
jeff657756 is offline   Reply With Quote
Old 11-16-2017, 03:23 PM   #7
MrTwenty6
MrTwenty6's Avatar
Drives: 2014 Camaro SS 1LE
NOWEEDs all the way.
MrTwenty6 is offline   Reply With Quote
Old 11-28-2017, 10:34 AM   #8
Wes137170
Drives: 15 2ss 1le
I had stock single tips and I went with corsa catback they also offer single tips but you will have to swap the fascia with one that fits the quad tips if yours don’t have it already i picked them because I couldn’t afford the borla lol, my backfires also increased and got louder.
Wes137170 is offline   Reply With Quote
Old 11-28-2017, 08:07 PM   #9
ThisGuyDrives
Drives: 2014 Ashen Grey Metallic 1LE/1SS/RS
Had the Borla ATAK cat back for about a year now. Worth every penny. Get compliments often on how good it sounds.
Just ordered some KOOKS headers thanks to 20% off Black Friday. So, it’s gonna sound real nasty next month.
Cold Air Inductions Intake
SPEC Stage 1 Clutch
BMR 1.4" Springs
Borla ATAK Catback Exhaust
Kooks 1 7/8" LT Headers w/ HF Cats
Last dyno tune was with just intake and catback exhaust did a 401/379.
ThisGuyDrives is offline   Reply With Quote
Old 11-29-2017, 12:31 PM   #10
jksynergy
jksynergy's Avatar
Drives: 11 SW SYNERGY SERIES/14 1SS 1LE
We have the Hooker Blackheart Race system on our 1LE. Long tubes, no cats, 3" exhaust all the way out with quad tips. Fit the factory diffuser perfectly. This the only picture I have to show it.
2011 Summit White Synergy Series Edition, the hot innocent woman named Ava that we show off around town, dressed in white complete with angel's wings. Sold, but never forgotten.
2014 1SS 1LE. Bama, sporting Red Rock Metallic demon's horns, when we are ready to get naughty and open a can of whoopass! Airaid, Spectre, Xpel,Bowler shifter Peddars, UMI, Ult Perf. Diode Dynamics, JRE Tune, XS Power battery,
Hooker Headers Blackheart exhaust,Powerbrake
InstaGram & Twitter: @jlouie62
FB: hangtimeracing
jksynergy is offline   Reply With Quote
Old 11-29-2017, 09:44 PM   #11
1bad1le
1bad1le's Avatar
Drives: 2013 Camaro 1LE
https://youtu.be/JSevh2i7l6g
TSP 2” headers, no cats, factory npp
https://youtu.be/9wmNMNmwE_k
2013 Camaro 1LE - SLP TVS2300, TSP 2" Headers, CAI, ADM FCM, NPP, Monster LT1 clutch, MGW flat stick, TSP LS3b cam, PAC springs, S&M Motorsports Tuning, 591 hp on Mustang Dyno
2016 GMC Denali 1500
Bulach Racing Team - Home of the fastest manual powered GM car in the world!
1bad1le is offline   Reply With Quote
Old 12-14-2017, 07:56 AM   #12
LSXDoc
LSXDoc's Avatar
Drives: 2015 1SS/RS/1LE
I went with the ZL1 version of the Retro Catback. Fit Great. The drivers side tips are a little off in this video, I later found out that I misaligned a hanger and it came loose.
https://youtu.be/cU4-tMKpTAc
2015 Red Hot 1SS/RS/1LE
ADM LSA kit
BTR Stg3 PD Cam
Stainless Power LTs w/ CATs
Stainless Works ZL1 Res. Delete 3" Retro Catback
DST Ported ZL1 TB
619RWHP / 539LB-FT
LSXDoc is offline   Reply With Quote
Old 12-15-2017, 08:48 AM   #13
94boosted
94boosted's Avatar
Drives: ‘17 1LE, ‘17 BMW 340, ‘18 F-150
I too am looking for something but want something that actually has a bit of a bump in power (can't replace headers/cats for classing reasons) and is lighter than stock.
94boosted is offline   Reply With Quote
Old 12-15-2017, 02:47 PM   #14
Sales@Phastek
Sales@Phastek's Avatar
Drives: 2016 1SS
Thanks.
Hey......we've had tons of our customers with SS's and 1LE's purchase the ZL1 quad tip systems and have installed them with no issues.
Sales@Phastek is offline   Reply With Quote
