10-09-2019, 10:00 PM | #15 |
I just got 21 psi reading the manifold pressure sensor. I feel better, thanks for the help!
10-10-2019, 10:07 AM | #16 |
Drives: 2019 Chevrolet Camaro 1LT 2.0T Join Date: Mar 2019
It's a must-have component for this car, that's for sure. You'll throw a CEL if you're driving balls to the wall consistently. I get one maybe once a month and clear it with my phone.
03-20-2021, 05:26 PM | #17 |
Drives: 2011 LS V6 (M) & 2019 LS I4 (AT) Join Date: Jan 2015
So I installed a equus boost gauge today by connecting to the bung on my Mishimoto cold side charge pipe. I'm essentially 200ish ft above sea level. I'm getting reading around 13-15. I was expecting 20 as well but nope. Not sure if it's the gauge or what. Is it possible I have a drop in boost from only having the cold side charge pipe installed so far on a stock intercooler?
2011 Camaro LS (MT) - Vitesse Throttle Controller / Flowmaster 40 Mufflers / CAI Intake / Apex scoop and washer relocate / Epic Engineering Catch Can / SS Stoptech Brake lines / BMR 1.2" Lowering Springs / IPF tune /Magnaflow X-Pipe / 25mm Mace intake spacer / BBK Long Tube Headers with High Flow Cats
(Current) 2019 Camaro LS I4 - Vitesse Throttle Controller / Mishimoto intake boot and charge pipes / K&N panel / BMR Sway Bars / GFB DV+ / ZZP Larger Throttle Body |
03-21-2021, 04:56 PM | #18 | |
Drives: 2016 M6 2.0T Join Date: Nov 2016
RS Package, HD Cooling Package, Brembo 6 Piston Front Brakes, SRP Racing Pedals, Soler Performance Throttle Controller, Dyno Tuned by Trifecta, Velossa Tech Ram Air, Mishimoto Intake, aFe Air Filter, Mishimoto Charge Pipes, ZZP 67mm Throttle Body, Trifecta T40 Stage 2 Turbo, JacFab Recirculation Valve, PTP Turbo Blanket, ZZP Catted Downpipe, Mishimoto Pro Cat-Back Quad Tip Exhaust, Mishimoto Catch Cans, Mishimoto Coolant Reservoir Tank, GM SEMA Grill, Ikon Motorsports Front Fascia Extension, Ikon Motorsports 1LE Spoiler, American Authority ZL1 Side Skirts, AMPP Quad Tip Rear Valance
Thread Tools | |
