Go Back   CAMARO6 > Marketplace > Sponsors Classifieds > Exterior Parts & Accessories
Old 01-16-2019, 02:36 PM   #1
RPI Designs
RPI Designs's Avatar
Drives: 2016 SS 6 Spd
2017-2018 Camaro ZL1 ProTEKt Custom Fit Front Bumper Skid Plates
2017-2018 Camaro ZL1 ProTEKt Custom Fit Front Bumper Skid Plates $208.05 With Code PHIL5 At Checkout.
https://www.rpidesigns.com/shop/item...r-skid-plates/
Scraping the front bumper of your 6th Gen Camaro ZL1 can cost you thousands in damages. This 2017-2018 Camaro ZL1 ProTEKt Custom Fit Front Bumper Skid Plates will bolt on in a few minutes and protect your Camaro for years.
ProTEKt Skid Plates attach to the underside of your front bumper to protect your valuable paint and factory front bumper cover, while blending perfectly with the bumper contours, for a factory, OEM look. Machined from ultra-durable High-Density Polyethylene, our plates will never wear out and are guaranteed for life. This slippery material lowers friction, so your bumper slides easily over bumps and surfaces, and minimizes stress on bumper mounting tabs, reducing damage, wear and tear. Each skid plate set is designed to be application specific, for an exact fit that helps to maintain factory ground clearance. Our easy installation kits come complete with all necessary stainless steel hardware and do not require any special tools or equipment. Our products are all designed, engineered, and manufactured in the USA.
Guaranteed for Life!
ProTEKt skidplates are made from 3/8" thick marine quality high-density polyethylene. This material was chosen for its superior outdoor performance, temperature stability, low coefficient of friction, and extremely high wear resistance. High-density polyethylene is commonly used in industry, as a replaceable wear spot on moving production lines, conveyor systems, and in automotive and motorcycle chain guides.
All hardware is full stainless steel for long term corrosion resistance, with nylock nuts for added security. Also, only metric (M6x1) nuts and bolts are included, to properly match the existing hardware on all modern cars.
With ProtektSkidPlates, you will have peace of mind that your precious paint and front splitter are protected during your daily, or not so daily, drive. If your skid plates wear out, contact us and we will replace them for life!
RPI Designs is offline   Reply With Quote
Old 03-11-2019, 03:40 PM   #2
Skipdaddie
Drives: 2017 F350
This shows up as $208 with that code.
2018 ZL1 A10
2019 Raptor
Skipdaddie is offline   Reply With Quote
Old 03-11-2019, 03:45 PM   #3
waterman
waterman's Avatar
Drives: Grandad's C2 L89
2018 ZL1 1LE sw/PDR
Old 03-12-2019, 02:14 PM   #4
RPI Designs
Hello,
Looks like the price changed on our website. Try code SS2007 for a better price.
Sub Total: $219.00
Discounts/Coupons -$21.90
Order Total: $197.10
Old 11-05-2019, 02:05 PM   #5
RPI Designs
Old 01-04-2021, 09:18 AM   #6
RPIDon
RPIDon's Avatar
Drives: Camaro
Send a message via AIM to RPIDon
Use coupon code RPISHELLEY5 for savings
RPIDon is offline   Reply With Quote
