12-13-2018, 06:30 PM | #1 |
BAMF SS
Weighed my car the other day
Figured I'd throw some info up, for reference for others. I weighed my car the other day and figured I would post the results:
3516 raceweight 3269 without me in it Details: 2016 1SS A8 (no other options except NPP, but it's obviously removed) Backseat and passenger seat removed Qa1 carbon driveshaft Lithium battery Exhaust removed at the x-pipe Bogart drag pack 1/8th tank of fuel Carlyle racing 15" rear brake conversion I plan on cutting more weight this winter.... looking to get it down to 3100 lbs without me in it, but we shall see.
2016 1SS A8: FBO + Circle D + P1X + Meth + Tuned by Pray Performance
Stock Longblock 800 SAE rwhp. 9.4 @ 145 mph. |
12-13-2018, 06:36 PM | #2 |
Drives: 2018 camaro ss Join Date: Aug 2013
You have link to drive shaft? That weight is super light
2019 charger scatpack FBO 11.16@122
2020 CAMARO LT1 6spd 11.02@ 135 dragy approved |
12-13-2018, 07:17 PM | #3 |
Drives: 17 SS a8 Join Date: Feb 2010
That does seem light for such minimal reduction. I need to get a set of scales. I am sure having them would motivate me to find a few more lbs to remove.
best et 5.83@121 with the 5.3 http://www.camaro6.com/forums/showthread.php?t=465472 |
12-13-2018, 08:43 PM | #4 |
Drives: 2017 HBM 2LT RS Convertible V6 A8 Join Date: Jan 2018
How many pounds can you save with lighter wheels? Not only will you reduce static weight, but the reduced moment of inertia will enable the wheels to accelerate and brake faster. Thoughts?
12-13-2018, 09:21 PM | #5 |
BAMF SS
https://www.jegs.com/i/QA1/122/JJ-22207/10002/-1
The wheels I have are pretty light as it is. Iirc they are only 12 lbs each. Not getting much lighter than that unless one plans on dropping $1,000/wheel for like a set of weld magnums or some other actual drag racing wheel.
12-14-2018, 05:25 AM | #6 |
Which battery are you running?
22 2SS 1LE M6 Summit White - RF, Flexfuel, LT2 intake, 95mm tb, ATI udp, VT ramair, full 28 dragpack - 11.68@122
16 1SS M6 LT2 intake + boltons on DR 11.0@126+ (Sold) |
12-14-2018, 07:57 AM | #7 |
BAMF SS
Shorai.... the lfx36 model, their biggest one... it comes in around 550 cca and 36 nah, iirc
It's a pretty heavy sucker .....
12-14-2018, 08:31 AM | #8 |
Wow it really is. Not any crazy savings over oem no?
12-14-2018, 10:08 AM | #9 |
BAMF SS
I dont know if you are being sarcastic or if you are not seeing the decimal point. Lol
But it offers ~40 lbs in weight savings
12-14-2018, 11:17 AM | #10 |
Yup didn’t see the decimal point
12-14-2018, 11:43 AM | #11 |
Drives: 18 ZL1 nightfall grey A10 Join Date: Apr 2018
Wow that battery is light!
I'm thinking of getting a Lithium Ion battery as well. I need one thats real good at powering everything including a small sound system. Of course when racing I will remove the sub box for weight as well. |
12-14-2018, 01:52 PM | #12 |
2016 NFG 1SS A8
12-14-2018, 03:23 PM | #13 | |
BAMF SS
12-14-2018, 05:04 PM | #14 |
Nice! gonna have to grab one, help off set some of the weight from the Whipple. The stock battery is shit anyway. Did you have to modify anything to install it?
2016 NFG 1SS A8
Thread Tools | |
