Old 12-28-2020, 08:50 AM   #15
Chrome383Z
Chrome383Z's Avatar
Drives: 2019 Camaro 2SS
Originally Posted by carguy55 View Post
updating with GM install info that has correct torque values for GM hardware etc. This has more install info that just for sway bars and links so only use what you need
https://ecom-dam.ext.gm.com/parts/do...s_84401187.pdf
Outstanding! This is just what I needed as I’m getting ready to do this install once the parts come in. Thanks!
2019 Shock 2SS A10. 2650@10psi/LPE HPFP/XDI+30/LT4 LPFP+JMS/Soler 95mm/Rotofab, E65, CSP 2” Headers/GESI GenII Cats. MM Wild/GM SG3 suspension/1LE Brakes, Velgen VF5 Wheels/GY SC3. JRE Tuned.
Chrome383Z is offline   Reply With Quote
Old 12-28-2020, 09:18 PM   #16
carguy55
carguy55's Avatar
Drives: 2018 1SS 1LE
The torque specs for the swaybar end links are not correct in that document if you have the new nut.
The new nut is PN 11548382.
Tighten the top nut to 89 foot pounds.
Tighten the lower nut to 96 foot pounds.
