11-01-2022, 03:26 PM | #1 |
Drives: 2016 chevy camaro Join Date: Dec 2021
How hard would it be to replace my thermostat?
My local chevy dealership is quoting me at 1,500 dollars to do the job. The part looks like it costs less then 100 dollars online. Is this is a quick simple job I can do or would it be better for me to pay someone to do this?
11-01-2022, 03:31 PM | #2 |
Drives: 1969 Z28,1992 Z28,1994 Z28,1999 SS Join Date: Oct 2021
What engine do you have? That might help with getting the correct answer.
23 ZLE Rapid Blue, M6. 6/27/22 TPW. Off assembly line on July 12th, 2022. To Dealer August 6th. Delivered August 8th. 129 miles. 99 SS Vert, Hugger Orange, A4, 806 miles 94 Z28, Black, M6, 595 miles 92 Z28, last car built at Van Nuys Plant, Red, A4, 125 miles www.last1992camaro.com 69 Z28, Dusk Blue, M4 29 Ford Business Coupe 28 Ford Pickup 24 GMC Denali 2500HD CCSB 4x4 22 Jeep Grand Cherokee 13 Ford F150 Crew Cab 4x4 |
11-01-2022, 03:41 PM | #3 |
YouTube is your friend…the V8 is easy, the V6 there’s more work, but still not difficult.
11-01-2022, 04:08 PM | #4 |
Drives: E92 BMW M3 Join Date: Oct 2012
WOW, $1,500 for a thermostat?!?!?!?! I am shocked.
J-Rod Built and Matt@FSP Tuned |
11-01-2022, 05:34 PM | #5 |
I have a V6 engine
11-01-2022, 05:58 PM | #6 |
Drives: 2016 2SS, 2008 HHR ECTO-2H Join Date: Aug 2009
I believe the one in my 2016 needs to be replaced as well. What's your car doing?
2016 Camaro 2SS. Hyper Blue, Ceramic White, Auto, MRC, and NPP.
1100 - 9/25 2000 - 9/28 3000 - 9/30 3100 - 10/27 3300 - 10/28 3400 - 10/29 TPW 11/09 3800 - 11/10 4300 - 11/24 4B00 - 11/25 4200 - 12/5 5000 - 12/7 6000 - 12/11 |
11-01-2022, 07:43 PM | #7 |
My coolant temp on my dash is showing 0. It doesn't read any temperature and my air conditioner doesn't work then. Also my fan keeps running constantly under the hood. The only way to get it right is for me to unhook my battery in my trunk and hook it back up. This only lasts for about a week then I gotta unhook the battery again to restart the coolant gauge. ITS getting very annoying.
11-01-2022, 09:33 PM | #8 |
Drives: 2016 2SS Convertible Join Date: Dec 2019
It’s probably not the thermostat, but rather the sending unit. The symptoms you describe are what it’s supposed to do if it “senses” abnormal temps. I’d start with the sensor.
Hyper Blue/Ash Gray A8 Magnetic Ride Control Dual Mode Exhaust 2019+ version Split Spoke Silver Wheels Navigation Silver Rally Stripes |
11-01-2022, 10:49 PM | #9 |
Drives: 2016 SS Join Date: Jan 2016
it is your thermostat, can't be that hard even if it is for a v6. i have the ss, it take me a couple minutes to swap it out.
11-02-2022, 01:00 AM | #10 | |
Somewhere in the Kalahari
Drives: 2021/18 (de-fresh) 3LT RS Join Date: Dec 2017
https://www.camaro6.com/forums/showt...=V6+thermostat Last edited by The Maverick; 11-03-2022 at 09:12 AM. |
11-02-2022, 07:29 AM | #11 |
Drives: 2024 Riverside Blue 2SS 1LE Join Date: Mar 2016
Even if the thermostat failed your dash would read the engine temperature. I would start by troubleshooting the coolant sensor, there is a chart that you can use to troubleshoot if you know how to use an ohmmeter or you could just parts bomb it. The sensor is $8. I would start with the obvious checking for damaged wires. There is also an outside sensor, is the outside temp reading correctly that has been known to cause issues. Just be aware after watching a couple videos on the sensor and thermostat the LGX is a PITA to work on.
11-02-2022, 08:42 AM | #12 |
Drives: 2016 Camaro 2SS Hyper Blue Metallic Join Date: May 2020
$1500?? Seriously. Do you have more then one GM/Chevy shop around. Take it somewhere else and get another quote. They have to be trying to screw you. Also, just take it to an indy and get a quote. You don't need to take it to a Chevy shop for a thermostat.
11-02-2022, 09:11 AM | #13 |
Monterey County Camaros
Mine ended up being the thermostat. The dash screen would read "--" for the coolant temp. The fan would run with the car off and I would have to disconnect the battery to turn it off. My tech told me that the thermostat is a spring that gets stuck and doesn't open all the way, which is why sometimes the fan stays on and other times it doesn't. Cost me $600, parts and labor, to replace at a dealer out here in California where prices are a bit higher. $1,500 is way to much.
Follow us on Instagram @montereycountycamaros
Last edited by S.Macias; 11-02-2022 at 11:30 PM. Reason: Reflect accurate pricing |
11-02-2022, 11:02 AM | #14 |
I'm more confused than ever now. So should I replace the sensor or the thermostat?
