Homepage Garage Wiki Register Members List Social Groups Calendar Search Today's Posts Mark Forums Read
Old 07-01-2020, 08:37 PM   #1
its_giooo1
Drives: chevy camaro
new wheels 20x10 20x11 MRC what tire size?
i just joined the forum and didnt see there was a tire and wheel page.
im getting 20x10 and 20x11 the offset is +23 +43 they are STANCE WHEEL SF07s. i also have mag ride with stock height. should i do 285/35 305/30 or 275/35? i kept seeing that i cant with mag ride. will rub. Hear you have to cut the rear axle bolt?
thank you!
its_giooo1 is offline   Reply With Quote
Old 07-01-2020, 10:16 PM   #2
MatthewAMEL
MatthewAMEL's Avatar
Drives: 2017 SS 1LE
20x10" and 11" are the standard sizes for the SS 1LE and ZL1.
That tire size is 285/30 and 305/30. The /35 is too tall.
You ordered wheels and don't know the offset? The 1LE OEM offsets are:
(F) 20, (R) 43
Hyper Blue SS 1LE
11/29/2016 - Delivered
Old 07-02-2020, 11:43 AM   #3
its_giooo1
Just got off the phone and the offset is +23 +43 !!
Old 07-02-2020, 02:07 PM   #4
Drives: 2018 Camaro 2SS
The standard "convention" that most people go with is 285/30/20 front, 305/30/20 rear with those aftermarket wheel sizes and offsets, very similar to the SS 1LE setup.
I wanted a bit more sidewall than that and less difference from stock SS MRC sizes, so I settled on 275/35/20 front and 315/30/20 rear, which works perfectly and looks killer with those steamroller style rears. Change from stock is only 3-4 revs per mile in the same direction, little to no impact on rake and stability under high load, and I've just finished a 1000-mile roadtrip with zero issues.
Magnuson Heartbeat TVS2300 80mm pulley | Kooks LT headers | JRE smooth idle terminator cam package | LT4 fuel system & injectors | JMS PowerMAX voltage booster
DSX flex fuel kit | Roto-Fab CAI | Soler 95mm LT5 throttle body | 1LE replica wheels | BMR rear cradle lockout | JRE custom tune
Old 07-02-2020, 03:59 PM   #5
its_giooo1
got it!!!!! ill go with 275/30. 315 wouldnt rub with mag?
thank you so much for the info!!!!!!!
Old 07-02-2020, 11:23 PM   #6
No rubbing at all with 315s. Note that my main body wiring harness is relocated on the driver side, see this thread for details.
As to front sizes, 275/30 will be too short and may cause stabilitrak/ABS issues when paired with 315/30 in the rear, because the front end will be 4.3% shorter while the rear only by 0.7%. You will also lose almost 18% of your front sidewall, so I bet the ride will be tangibly worse.
I'd say either simply go with the SS 1LE specs, or have 35 aspect ratio in the front. I can recommend my setup, it works perfectly well; if you want to fill the wheel wells a bit more, you can do 285/35 fronts (with small spacers) paired with 325/30 rears, it will still work fine.
(https://tiresize.com/comparison and https://www.wheel-size.com are your friends.)
Old 07-05-2020, 08:52 PM   #7
sergenohra@hotmail.com
Drives: chevrolet camaro 2.0 manual
315/35/20 275/40/20
hi guys.
im new to this forum.i have a camaro 2.0.i ordered new wheels set mrr m650 20X10 20x11.i was wondering if 3-5/35/20 rear et43 and 275/40/20 front et 23 will fir on them.thank u
sergenohra@hotmail.com is offline   Reply With Quote
offset, wheels, wheels and tires
Copyright ©2000 - 2021, vBulletin Solutions, Inc.
