Old 06-24-2020, 03:46 PM   #1
bpal1211
Drives: 2020 SS 1LE
Starter Issue
What's up everyone.
I have a 2016 SS. And within the first 5 months of owning the car, I've blown through 2 starters (covered by warranty thankfully). However, this is not something I want to be dealing with for the next few years.
The only modification the car has is a stage 1 GPI SS1 cam. I have a suspicion that this could be part of the issue, almost like the OEM starter has a problem turning over the engine due to the cam?
Has anyone had this type of experience and was there a fix?
Thanks.
bpal1211 is offline   Reply With Quote
Old 06-24-2020, 05:40 PM   #2
SSDan
SSDan's Avatar
Drives: 2016 1SS 6MT NPP
More info needed. Does the starter have issues on a hot start or cold start or both? Many of us deal with a slow crank on a hot start. I have never had an issue on a cold start. Do you have headers which could put even more heat into the starter causing it to heat soak and then fail?
As to a remedy for the hot start issues - there has not been a definitive solution. Many have tried new starters, new batteries or both as well as increased heat shielding. Some have even added a second engine to chassis ground cable. The results of all this has been mixed. I just deal with it. I avoid making multiple short stops on a hot engine as on the second or third stop - that is when I get a slow crank.
Good luck and keep us posted.
476 rwhp/440 rwtq (sold)
Old 06-26-2020, 07:45 AM   #3
avalonandl
avalonandl's Avatar
Drives: 2019 ZL-1
How is your battery, fully charged and reads 14 v?
Did you have it load tested.
Old 06-26-2020, 02:41 PM   #4
soloknight6
SoCal HT5! SD
soloknight6's Avatar
Drives: 2016 red hot 2ss M6
If you have the OEM battery, that's the problem. Ditch it.
soloknight6 is offline   Reply With Quote
Old 11-02-2020, 10:32 PM   #5
Nitefall17
Drives: Camaro 1SS A8 Vert
Have them check the BCM & Grounds
Nitefall17 is offline   Reply With Quote
Old 12-04-2020, 11:02 AM   #6
Nitefall17
FYI-There has been 3 revisions on the BCM, I have a 2020 put in my car.
Old 12-08-2020, 04:17 PM   #7
LfuenteSS
Drives: 2016 Camaro SS
I had the same problem with a 16 SS. Luckily the dealer replaced the starter but now with 50k miles it seems to be almost failing again. Bottom line the OEM starters are a P.O.S.
LfuenteSS is offline   Reply With Quote
Old 12-08-2020, 04:27 PM   #8
Nitefall17
Originally Posted by tadre1 View Post
NiteFall .. how is your ride holding up so far .. after the fixes?
knock on wood, everything is all good.
Old 12-10-2020, 12:30 AM   #9
Nitefall17
Still no word on my car.
It sucks , I went through the same problems.
You can PM if you need anything.
Old 12-24-2020, 03:59 PM   #10
Biscuit.fr
Drives: Red hot ZL1 A10 2017
https://www.camaro6.com/forums/showthread.php?t=586153
So
Check the ground cable
It may fix something
Biscuit.fr is offline   Reply With Quote
