02-12-2020, 12:08 PM | #1 |
Drives: ZL1 1LE SUMMIT WHITE Join Date: Feb 2018
Trunk Won't Open!
My car is still in winter storage and I went there the other day just to fire it up and let it run for a while. I tried to open the trunk with the button on the door. Nothing. Tried the fob release. Nothing.
Any ideas? I've got a cage and rear seat delete so it'll be a real pain in the arse to go through the inside to use the emergency release...
2018 ZLE * StudioRSR Half Cage * SkidmarkGarage Rear Seat Delete * ZL1ADDONS Lift Pads * Roto-Fab CAI * Forgestar CF5-V's * Michelin PS4S * Racequip 6 Pt. Harnesses * Sub-strap Brackets by Carmena Performance * Speedhut Shift Light * Leroy Eng. Hidden Hitch (for the TYR RAT)* Gen5DIY Rapid Flash 3rd Brake Light * KOOKS 2" LT * Green Cats * AWE Cat-back Track Edition *
________________________________________ 2005 NISSAN TITAN 1997 BMW E39 (Thug In A Suit) R.I.P. 10/04/18 2002 MAZDA Protege 5 (Time Attack, Hillclimb) SOLD |
02-12-2020, 12:56 PM | #2 |
Drives: ‘18 ZL1 1LE Join Date: Mar 2019
Press down on the trunk and try again. Happened to me once.
02-12-2020, 01:32 PM | #3 |
Drives: 2016 2SS Convertible Join Date: May 2012
When you say "nothing" does that mean you can hear the electric release activate but the trunk doesn't open, or does it mean the battery in the car is low and the electric release doesn't activate.
If you hear the electric release activate but the trunk doesn't open then the suggestion above to put some downward pressure on the trunk lid should do it. That has happened to my car too. If the battery is low then you can open the hood and put a charger or jump start on the "jump start" posts to get 12V to the car. Then try the release to see if the trunk opens. Good luck! |
02-12-2020, 02:11 PM | #4 |
The car was running while this happened. I also tried pushing down on the trunk lid. There was no sound from the release mechanism when both methods were tried.
02-12-2020, 02:28 PM | #5 |
Thank you Al Oppenheiser!
1. if it's got power, pushing down sometimes works.
2. if it doesn't, happy spelunking. |
02-12-2020, 06:25 PM | #6 |
Drives: 2019 Camaro SS M6 Join Date: Jan 2020
Maybe a fuse. Batteries in your fob low. That's where I would start.
02-13-2020, 12:47 AM | #7 |
Drives: 2017 ZL1 Join Date: Aug 2016
Valet mode?
02-13-2020, 01:35 AM | #8 | |
Drives: '19 camaro 2ss Join Date: Jan 2020
02-13-2020, 03:14 PM | #9 |
Drives: 2018 ZLE Join Date: Feb 2018
That happen to my Gen5 Camaro and found that the wires had been pinched by the lid it self. Was a easy fix.
02-13-2020, 06:19 PM | #10 | |
...when I get it open.
02-13-2020, 06:54 PM | #11 |
Drives: 2018 ZL1 Camaro 6M Red Hot Join Date: Aug 2013
Here is a stupid question: was the electric parking brake set? I know with my M6, I cannot open the trunk unless the parking brake is set.
People are a lot like slinky's: not very helpful most of the time, but they bring a smile to your face when pushed down the stairs...
02-13-2020, 07:46 PM | #12 |
Drives: 2023 ZL1 M6 Join Date: Sep 2018
Mine just did it a few days ago. I had to go through the car to pull the release. Lots of fun for a 6-2 290lb dude. Hahaha. Worked perfect since.
2024 Riverside Blue ZL1 M6
Magnuson 2650R, Roto Fab Big Gulp, NW 103, ARH 2 inch LT's, Stainless Works NPP Signature Forged 20x10.5/20x11.5, BMR springs, BMR Cradle lockout, AAD Billet Control/Trailing arms 2023 Vivid Orange ZL1 M6 - sold 2019 Riverside Blue ZL1 A10 - sold |
02-13-2020, 08:24 PM | #13 | |
No. And I'll try setting the brake...
02-13-2020, 08:52 PM | #14 |
Drives: 18 ZL1-1LE, 10 JKU Join Date: Jul 2018
i didn’t think it would open while running?
Thread Tools | |
