Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Camaro Z/28 Forum - Z/28 Specific Topics
Old 10-11-2020, 09:54 AM   #1
Cvargz4589
Cvargz4589's Avatar
Drives: 2015 Chevrolet Camaro Z/28
Storing a Z for winter
Hi everyone! I’m not sure if there was a thread on this topic yet or not since I’m a newbie to the forum & a newbie Z owner. Just cleaned it up as the first step for hibernation. I have a ctek battery tender & stabil fuel stabilizer on order from Amazon. Also, bought the GM fitted indoor car cover to keep her covered up. It will be in a heated garage. Since the battery is in the trunk, any tips to keeping the trunk light from staying on while the battery is hooked up? Or do you recommend taking the battery out completely? Anymore recommendations for storing a Z for winter or an extended period of time in general?
Thanks!
Cvargz4589 is offline   Reply With Quote
Old 10-11-2020, 10:14 AM   #2
0stones0
It don’t come easy.
0stones0's Avatar
Drives: 2010 2SS RS M6
You can hook the tender up under the hood. Have a look see and you’ll find a jumper post for the positive. At least, there is on mine.
0stones0 is online now   Reply With Quote
Old 10-11-2020, 10:15 AM   #3
SIM GhostrdrZ
SIM GhostrdrZ's Avatar
Drives: ‘14 Z/28 ‘14 ZL1 M6 vert
No worries on trunk light. It’s on a timer as is all other systems to turn off as not to drain the battery. So hook up tender and I just set trunk down but don’t latch it and I have a hole in car cover for tender cable so it doesn’t touch car body. Do something as not to flat spot your tires, park on rubber flooring, carpet pieces or some put up in the air via stands or a lift. Change oil/filter before storage or before you drive it in the spring(depends on whom you ask).
SIM GhostrdrZ is offline   Reply With Quote
Old 10-11-2020, 10:31 AM   #4
SIM GhostrdrZ
The under hood posts are probably good to use as well. I just have an old habit of charging directly to battery or battery removed. My reasoning is not to burn out sensitive computer modules or wiring.
Old 10-11-2020, 01:11 PM   #5
X77-69z28
X77-69z28's Avatar
Drives: 69 Z/28, 70 Z28, 99SS, 15 Z/28 2018
I always over inflate the tires to 45lbs. I hook my battery tender right to the battery. The trunk will close over the wire. I don’t want to find anything in the trunk!
Buddy
69 Z/28 burnished brown, m-21 owned since 1978
70Z/28 forest green M40 CE block PROJECT
99 SS hugger orange 6spd no t-tops 1 of 54
15 Z/28 white AC, radio
X77-69z28 is offline   Reply With Quote
Old 10-11-2020, 07:11 PM   #6
69L48Z27
69L48Z27's Avatar
Drives: 2015 Z/28; 1969 Camaro SS
I either use the under hood posts or connect to the battery direct. When I connected to the battery I popped a truck pan plug out and ran the maintainer through that hole.
69L48Z27 is offline   Reply With Quote
Old 10-12-2020, 09:42 AM   #7
4 FN 27
Drives: 2015 Z28
Thread from back in 2015..."Winterizing"
https://www.camaro5.com/forums/showp...6&postcount=19
"Resale value is my beneficiaries problem...unless they can bury my in my Z...problem solved."
4 FN 27 is offline   Reply With Quote
Old 10-13-2020, 08:30 PM   #8
Cvargz4589
Cvargz4589's Avatar
Awesome!! Thanks for all the pointers! Great info!
Old 10-16-2020, 11:08 AM   #9
SIM GhostrdrZ
I like it. Routing battery tender through trunk pan plug now.
Thanks
Old 10-16-2020, 11:56 AM   #10
The_Raging_Bull
Raging Bull Reborn
The_Raging_Bull's Avatar
Drives: '09 CGM Z063LZ '15 RH Z/28 #0631
I just used the post in my engine bay to hook up the maintainer, then crack the hood with the maintainer 25 ft wire coming out to the maintainer beside the car. Really its whatever floats your boat. I have the best Optima PC1200 dry cell battery in my trunk..not the lead acid original battery, the key idea is to keep it properly charged with a desulfating maintainer.
Toy 1 '15 RH Z/28 w/AC & Radio S/N 0631
Toy 2 '09 CGM Z06 3LZ
My DD: '17 Ford Mustang GT
Her DD: '14 F150 Ecoboost 3.5
The_Raging_Bull is offline   Reply With Quote
Old 10-16-2020, 12:15 PM   #11
0stones0
It don’t come easy.
0stones0's Avatar
Ran a pigtail from the engine post, out the front of the grill, next to the left blinker. Got a nice rubber plug that fits over the end of the pigtail when it’s not hooked up, to keep it clean and dry. Keep it hooked up 365 days a year. Just replaced the factory battery this year.
Old 10-17-2020, 09:20 PM   #12
Cvargz4589
Cvargz4589's Avatar
So I checked the fluids, added fuel stabilizer, put some thicker pieces of cardboard between the tires & cement garage floor, hooked up the brand new ctek battery tender (ran through the bottom of the trunk via pulled drain plug), & covered her up with the new GM fitted Camaro indoor cover. As you can see, she’s all set for hibernation until spring (unfortunately)!
Thanks again for all the pointers on getting my Z ready for her first winter up north!
Old 10-20-2020, 09:29 AM   #13
DannyZ
Drives: 2014 ZL1
Dryer sheets (Bounce, etc.) in the cabin, engine bay, and trunk.
Moth balls or flakes under the car and around it. These will dissolve over time so should be refreshed. Yes, your garage will smell for a few days but it's better than mice.
Steel wool in the exhaust tips.
I hate mice.
DannyZ is offline   Reply With Quote
Old 10-20-2020, 11:44 AM   #14
denboy1
Drives: 2014 2ss Convertible
I flip the floor mats and put Irish Spring on all the mats, in the trunk and engine.
Also might want to put some bumpers on the sides.
denboy1 is offline   Reply With Quote
