04-09-2020, 09:02 AM | #99 |
Most of cases the wireless charging pad is useless because of the size differences in cell phones now! Just use your charger cable and plug into the USB port in the center console and motor on! That’s the way I do it. No biggee!
04-09-2020, 09:42 AM | #100 |
Drives: 2023 Black Camaro 2SS Join Date: Sep 2017
Wireless CarPlay is a game changer for me!
05-05-2020, 01:35 PM | #101 |
Drives: 2017 2LT RS Join Date: Nov 2018
Yes, it is a great update, but you can make wireless Carplay and AA now with your current headunit. Just need some time
https://www.camaro6.com/forums/showt...light=wireless |
05-05-2020, 03:52 PM | #102 |
Drives: 6 on the Flo' Super Sport Join Date: Jan 2011
I prefer a stick. Whats next 15 speeds??….No check it out...it will be a Shiftless CVT Continously Variable Transmission, like in a Pacifica or Nissan maxima.
05-05-2020, 05:56 PM | #103 |
Drives: like an old lady Join Date: Jun 2012
i don’t like carplay because it interrupts the music when i try to do anything with a text message. other than that it’s ok. not something i’d trade cars for.
05-05-2020, 10:39 PM | #104 |
Drives: Chevy Camaro Join Date: Apr 2020
05-06-2020, 12:09 AM | #105 |
2020 Shadow Gray 2SS
I ordered a 2020 2SS (non-1LE) but with NPP, MRC, A10, Red Calipers, Black Rims, and a few other options (about $1k worth) and got it for well under $45k... I'm certain I could have ordered a 2SS 1LE for less than $50k (in SoCal) as the 1LE would have included the MRC, Red Calipers and NPP (which were most of my most expensive options).
2020 SGM 2SS - A10, NPP, MRC, Red Calipers, Black Camaro Fender Badge, Footwell Lighting
Added after delivery: - GMP CAI, GMP Black Strut Tower Brace, MRR017 1LE Wheels, SS Armrest, Black Fuel Door, Stainless Sport Pedals, SS Wheel Caps, Black Lugs/Locks, GM Splash Guards, DD Smoked LED Markers, Smoked Rear Reflectors, Mishimoto Catch Can, Xpel PPF - Full Front, SunTek 35% Tint, CeramicPro coating, RST Stainless Brake Lines, Castrol SRF, MSD Super Conductor Wires Left: My "fun" ride. Right: My "work" ride: a Gulfstream G600. One's top speed is 180 Mph, the other, 620 Mph... |
05-31-2020, 06:48 AM | #106 | |||
Hot Camaro
To make matters worse, wireless charging is actually bad for your phone - it accelerates the degradation of your battery because it's constantly being run from battery and recharged. Wired charging has protective circuitry that diverts power to run the phone while the battery stays completely topped off. The result with wireless charging is that you actually put the battery through significantly more total charge cycles in the same span of time compared to wired charging. Wireless charging further accelerates battery degradation when done while the phone is in use. In a car, with the phone being used for something like navigation, it's going to be running at a warmer temperature because it's under load. Charging the battery while in this state is bad for the battery and actually causes premature breakdown. I'm happy to stick to called charging with a quality adapter that can fully operate my phone with no need to also pull from battery at any point. |
05-31-2020, 12:45 PM | #107 | |
Drives: 19 Chevrolet Camaro 2SS 1LE Shock Join Date: Apr 2020
As for wireless charging, I am actually glad my Camaro doesn't have it. From 2019 onwards, it's no longer on the 2SS trim. You have to have a ZL1 to have it. I have a OnePlus 7 Pro and I intend to keep it a while. It doesn't come with wireless charging so the wireless pad would have been a waste of space for me. I use that space for my phone and it works well. And yeah, if you have a case, wireless charging could cook your battery. Most phones are also sealed so replacing battery is a PITA. Sent from toaster or something
Current:
2019 Chevrolet Camaro 2SS 1LE M6 Shock GM Performance Intake and that's it, because driver mods before car mods Past: 2009 Mazda RX-8 GT M6 Velocity Red Mica (Sold) 2015 Chevrolet Corvette Z51 2LT M7 Velocity Yellow Tintcoat (Flood totaled) |
05-31-2020, 01:18 PM | #108 | |
Drives: 2017 SS A8 Hyper Blue/White Stripes Join Date: Jun 2010
You’re also not correct about the comment “MRC too“. MRC is not offered on the LT1 as a option.
2017 Camaro 2SS Hyper Blue
2011 Camaro 2SS 2004 Corvette CE SOLD |
06-01-2020, 06:47 AM | #109 | |
Hot Camaro
"If you start adding performance tire package, the cooling required to call it a track version and MRC your back to a SS." What I did a poor job of saying was that the car you were describing wouldn't have actually been an SS because MRC isn't standard equipment on the SS. And, if you -were- able to add MRC to the LT1, it would need to be added to the SS as well to actually be similarly equipped. |
06-01-2020, 06:49 AM | #110 | |
Hot Camaro
And good point on how having a phone in a case causes it to hold a bit more heat while charging (regardless of whether cabled or wireless) compounding the problem. |
06-01-2020, 07:14 AM | #111 | |
Drives: 2016 Camaro 2SS Hyper Blue Metallic Join Date: May 2020
06-01-2020, 07:22 AM | #112 | |
Hot Camaro
My girlfriend's iPhone, at just a slightly older age, will drop battery level aggressively throughout the day without a significant amount of use. She wirelessly charges every night. My work iPhone, at about 2.5 years old, showed similar signs of battery run-down but it got MUCH heavier use than her iPhone and was plugged in and using location services (navigation, mileage tracking) a lot (I travel for work). Never wirelessly charged (not supported). In other words, three phones... Two (mine) are put through hard use and either aren't showing signs of battery degradation or it took a long time for it to appear. The third is lighter use but showing signs of battery issues earlier in life and has been wirelessly charged consistently. |
