01-27-2020, 08:09 AM | #1 |
Drives: 2018 Summit White 1LT Join Date: Jan 2019
Turn signals start slow and speed up after
As the title suggest, the turnlights work fine but after setting them they start blinking normal for 2 to 3 ticks and after wards speed up rapidly this is happening to both sides but not to the hazards.
I checked all BCM fuses in front and rear fusebox and replaced them all preemptively. Any other ideas as to what this might be? More about the car this is a 2.0T 1LT, i have the GM dark tailights with LED i added the resistor kit from Wildhammer. I now have the RS headlights (yesterday) with the proper Gen5DIY harness but it was happening before this with my OEM Halogen lights. Ive checked all bulbs and seem to be ok. |
01-27-2020, 09:09 AM | #2 |
Drives: Chevy Camaro Join Date: Jul 2019
I'm betting it's resistor related. The car thinks the bulb is out.
01-27-2020, 09:22 AM | #3 |
Thanks ssmofo, Do you think that it might be the resistor for the tailights? Since it was happening long before i installed the new headlights?
01-27-2020, 11:32 AM | #4 | |
As ssmofo said, the BCM thinks one of your turn signal bulbs is out, so you need to add a resistor on both sides, plus this harness gives you a 3rd resistor for the LED reverse lights (one resistor is enough for those, as they light up together). If you have the correct harnesses, you need to check the two resistors on the top harness, there may be an issue with one or both or the wiring broke loose somewhere.
01-27-2020, 12:45 PM | #5 |
Hey arpad, thank you for your detailed message,
You are correct i did order the third harness and it worked fine for some time. Thankfully wildhammer has great customer service and they are working with me now to get it done under warranty from gen5diy. |
01-27-2020, 03:04 PM | #6 |
Two Lane Blacktop
Drives: '18 Camaro 2SS Join Date: Jul 2019
The harness on the column was tight on mine if I dropped steering wheel down the blinkers where all out of wack
01-28-2020, 12:39 PM | #7 |
Drives: 2016 Camaro RS Join Date: May 2016
the resistors may have went bad. if its 50watt resistors, its said that the 100watt resistors tend to last longer.
2016 Summit White 1LT RS, Brembo Brakes, NPP Exhaust,Front Glowtie, Rear Red Glowtie, Adrenaline Red Interior
10-06-2023, 07:50 PM | #8 |
Drives: Camaro 2016 RS Join Date: Jan 2022
I am about to buy my first Camaro from 2016 and during the test drive, I've noticed that when setting the turning light, they start "clicking" slow then after 2-3 seconds they click very fast and that's a little annoying.
Is this normal or it's a problem similar to OP's message? |
