03-29-2016, 12:52 PM | #29 | |
Drives: 1969 Mustang MaCh1 Join Date: Nov 2015
$65k seems to be on the higher end of what people are willing to pay for the super pony cars.
1969 Pro-Touring MaCh 1 - CHP 427w 10.8 comp - 3140 lbs. - 460 rwhp / 490 rwtqT56 Magnum || 14" 6 piston front / 13" 4 piston rear Wilwood brakes || Hydraulic clutch || 9" Detroit Locker || TCP Coilovers || Forgeline Wheels 18x10 275/35 front, 19x12 325/30 rear |
03-29-2016, 01:15 PM | #30 | |
Drives: 2001 Camaro SS Join Date: Nov 2009
With the potential of this Z/28 being alot lighter than the 5th gen Z, I still think you will see the LT1 as the power plant with a power bump via intake and exhaust. If the car could get down in the 3400 lb area thats 400 lbs give or take a few than the 5th gen, itd murder it even with less power than the 505 hp the LS7 had.
2001 Camaro SS- M6 cone killer
03-29-2016, 02:05 PM | #31 |
Drives: 1970-1/2 Z-28, 2017 ZL1 Join Date: Sep 2012
I don't care how you generate power, as long as it is responsive, repeatable, and durable. In my experience, the cooling of S/C motors has greatly improved, especially when you are willing to mod a little bit to improve airflow which I don't see the ZL1 having a problem with. Heat soak is something I was concerned about with my current ZL1 but found it to be WAY OVER RATED from a concern perspective. I can run hot laps all day in the Florida summer with little to no power lose due to heat. I get tired before my motor does.
03-29-2016, 02:27 PM | #32 | |
Drives: 21 Bronco Join Date: Jun 2012
03-29-2016, 02:32 PM | #33 |
#becauseracecar
Drives: 2016 SS Sedan, 2016 Camaro SS Join Date: May 2015
I'm having trouble figuring that out too. CC brakes, 19' wheels, A/C and Radio delete, rear seat delete, sound deadening delete, mechanical light weight Recaros. Electric windows are now lighter than old mechanical windows so that doesn't matter. But then you have to add back the aero and what appears to be a large wing in the back. If they do all that, this will really be a track only car. (I'm not saying that's a bad thing, just that it will make it unstreetable at all).
03-29-2016, 02:37 PM | #34 | |
GM has done some amazing things as far as lightening cars, but a V8 Camaro that weighs as much as Z51 Corvette might be stretching it IMO |
03-29-2016, 02:49 PM | #35 | |
I used to be Dragoneye...
By doing things such as lightweight CC rotors, lightweight shocks, thinner glass, no A/C compressor, just one speaker, a fixed rear seat, no sound insulation, and 19" wheels...they were only able to take about 80 lbs out of the chassis compared to a 1SS. Today, the "2014 Z/28 method" would produce an SS that's just about 3600 lbs even. IMO, 3400 lbs isn't going to happen unless you replace every body panel with carbon fiber, use CF wheels, CF driveshaft, polycarbonate "glass", hollow/hard racing seats, and an airbag delete. It can be done, physically...but if you thought $73,000 was a lot of money... |
03-29-2016, 09:39 PM | #36 |
"1/LE Rebel Alliance"
Drives: 18 Black 1SS 1LE “Siouxsie Join Date: Nov 2013
I'd be perfectly fine if they used the LS7 again. Less weight and better suspension on this Alpha platform will make this next potential Z a wonderful machine. The rumors are that the next Z/28 will be a 302 to point back to the legacy of the 68-69s
The only problem I see is redundancy at the higher levels of the Camaro with the emphasis on pushing a 1LE, ZL1 and the next Z/28. |
03-29-2016, 09:55 PM | #37 | |
Remember the Charleston 9
Drives: 2004 KME PREDATOR, 2014 2SS/RS/1LE Join Date: Nov 2008
2002 V-6 5 speed rally red (current camaro) Also driven:1992 Z-28 305 auto Red w/ black stripes (anniversary), 2001 V-6 auto light pewter metallic,1991 RS V-6 auto Black |
03-29-2016, 10:00 PM | #38 | |
03-30-2016, 12:14 AM | #39 | ||
Drives: 2015 SS 1LE Red Hot, 1970 Chevelle Join Date: Apr 2012
03-30-2016, 04:26 PM | #40 |
Drives: 2015 Z/28 #397 2022 ZL1 #1799 Join Date: Jul 2009
I think the consensus is a small(er) displacement, high rpm engine for the new Z/28. However I don't think they can get what they want without some type of FI, unfortunately.
03-30-2016, 05:28 PM | #41 | |
03-31-2016, 11:36 AM | #42 |
Drives: Nothing Fast (Yet) Join Date: Oct 2015
Was this last weekend (3/19-3/20)? I know two people at that track day. 1 had a water pump blow (it happens to most cars eventually) and the other had no cooling issues, he was running a DeWitts radiator and intercooler with a Halltech intake with no overheat warnings.
