Go Back   CAMARO6 > Marketplace > Sponsors Classifieds > Exterior Parts & Accessories
Old 01-19-2016, 09:04 AM   #1
RPIDon
RPIDon's Avatar
Drives: Camaro
Send a message via AIM to RPIDon
RPI Designs 2016 Chevrolet Camaro STO N SHO Removable Front License Plate Bracket
Big Mike's Performance Parts' STO N SHO for 2016 6th Generation Chevrolet Camaro 1LT, 2LT, RS, and SS
This bracket DOES NOT fit if you have the factory ground effects or 1LE performance package. Please order the Hot Wheels bracket.
Big Mike’s Performance Parts’ 6th Generation Camaro STO N SHO™ is an aftermarket quick release front license plate bracket that is designed for those cars whose appearance would be ruined by use of the factory mounting location. Stay in compliance with state law by simplySTOing your front license plate when you want to SHO the beauty of your car.
Big Mike’s Performance Parts’ STO N SHO™ is a two-piece quick release front license plate bracket consisting of a front license plate holder and a base mounting plate.
Removal and installation of the front license plate is easy
•Requires only the pull of a spring loaded pull pin
•Remaining base plate is virtually undetectable
The STO N SHOTM aftermarket quick release front license plate bracket is manufactured in the USA using quality materials and parts. The front and base plates are precision laser cut and hand burnished. Each tube and rod is machine cut and hand cleaned. Each STO N SHOTM aftermarket quick release front license plate bracket is expertly hand welded and drilled. After it’s assembled the base plate welds are ground smooth. The bracket is then anodized black. The final step in the process is to install the pull pin and test the product. While the bracket may look simple in appearance, a lot of time and work goes into making each 6th Generation Camaro STO N SHOTM aftermarket quick release front license plate bracket to ensure you receive a quality product.
•Constructed of 5052 and 6061 aluminum
•Welded and anodized black
•Built to last and comes with a limited life time warranty
Big Mike’s Performance Parts” STO N SHO™ requires small holes to be drilled on the underside of your vehicle. These holes are not visible and in no way detract from the look of your car.
•Requires no holes to be drilled on the underside of the car
•2016 Camaro
All parts required for installation included, however, tools are required.
*Actual bracket may vary based on model
Item # 16-7950
Website Link : http://www.rpidesigns.com/shop/item....plate-bracket/
RPIDon is offline   Reply With Quote
Old 04-14-2016, 09:01 AM   #2
RPIDon
RPIDon's Avatar
Drives: Camaro
A great way to display and remove your front license plate!!!
Old 04-20-2016, 06:30 PM   #3
SkipNWis
SkipNWis's Avatar
Drives: 2016/SS Has had 4 Gen 5's
What's the hot wheels bracket and where can I get it.... Please pm me info.
SnoWhite
SkipNWis is offline   Reply With Quote
