Old 10-19-2019, 12:56 AM   #1
Calcanuck
Calcanuck's Avatar
Drives: 2017 Hyper Blue 2SS
New Pads Question - Turn Rotors?
When you are installing new track pads of the same compound are your turning the rotors if the rotors are not groved? Still measuring about 33mm thickness.
Thanks
Hyper Blue 2SS, 6MT, NPP, 6 piston Brembo, 1LE suspensions upgrade, ZL1 Seats, Wheels & Tires
Calcanuck is offline   Reply With Quote
Old 10-19-2019, 08:33 AM   #2
TJay74
Last I read when you can do pad changes that as long as the rotor is not showing excessive pad deposits from the previous pads you just need to burnish in the new pads per the pad manufactures instructions.
2017 Camaro SS 1LE - Procharger D1SC w/ Tial 2" BOV & Race intercooler / ARH full length catless headers / Alky meth injection system - 650rwhp on conservative tune SOLD
Old 10-19-2019, 09:40 AM   #3
Indy_62
Drives: 2017 2SS / 2003 S10 Crew Cab
As long as the rotors seem to be true (no pulsation when braking) and they appear good physically; you should be good. It was previously an industry standard to turn rotors whenever pads were replaced; this was endorsed by manufacturers of the machining equipment and the replacement rotors.
Never say never!
Indy_62 is offline   Reply With Quote
Old 10-19-2019, 11:00 AM   #4
Calcanuck
Calcanuck's Avatar
Thanks for the advice. I am going to just replace and bed the pads.
Old 10-19-2019, 02:46 PM   #5
Junkyardspecial
Junkyardspecial's Avatar
Drives: 2018 ZL1 1LE
Sometimes I hit the rotors with a little 200-400 grit sand paper.
Subscribe to my Youtube channel!
https://www.youtube.com/c/Junkyardspecial
Will buy your GoodYear Supercar 3R Take offs!
Junkyardspecial is offline   Reply With Quote
Old 10-19-2019, 11:10 PM   #6
TrackClub
TrackClub's Avatar
+1 lol! Frankly, even with different pad deposit proper bedding in accomplishes the change over just fine.
Old 10-20-2019, 12:38 AM   #7
cdrptrks
cdrptrks's Avatar
Nope. Even with a groove/lip around the edge my rotors have been holding up fine with multiple sets of stock brake pads.
Also I believe garnett paper is supposed to be used rather than sandpaper if changing pad compounds but you will probably be fine swapping pad compounds without touching the rotors.
Old 10-23-2019, 01:11 PM   #8
Jimbeau11
Jimbeau11's Avatar
Drives: '18 Black SS 1LE; '01 Corvette Z06
I've tracked my C5 Z06 for over 12 years and hundreds of pad changes without ever once turning a rotor. Only one season so far with the SS 1LE, but went through 4 sets of pads and 3 different compounds on the stock rotors without doing a thing.
For the record, I've also never turned rotors on my street-driven cars either and never once had a shop recommend it either for that matter.
Jimbeau11 is offline   Reply With Quote
Old 10-23-2019, 01:34 PM   #9
mt.nichols
Drives: '19 ZL1 1LE
Swap pads, complete a proper bedding procedure, carry on.
mt.nichols is offline   Reply With Quote
