06-06-2018, 09:45 PM | #29 |
Drives: 2017 2LT/RS & 2013 2LT/RS vert Join Date: May 2014
06-07-2018, 09:37 AM | #30 |
Drives: 2017 50th Anniversary 2SS Join Date: Sep 2016
Haha.. That's why it's been so shiny!.
06-07-2018, 10:48 PM | #31 |
06-08-2018, 05:58 AM | #32 | |
Thank you Al Oppenheiser!
The very first time I foamed the top was 8-9 months when I was doing prep for the 303 treatment, and I spent an hour or so just on the top between wash, scrub, rinse, using the 303 cleaner, then re-rinse and dry. The top is rarely up when I drive, so usually just the lint roller, spot treatment for the bug and bird bombs, and a pooling rinse is enough to get it clean off. But after a few trips with the spousal unit to play in the surf during TS Alberto it picked up a lot of salt spray and fine grit sand. So it was due for a good cleaning. |
06-10-2018, 11:41 AM | #33 |
Sure, why not?
Drives: 2016 Camaro 2SS, Jeep JKU Rubicon Join Date: Mar 2015
So, am I correct in thinking that you:
1. Hose (or pressure wash) the car down with plain water 2. Spray foam all over car 3. wait 5(?) minutes for soap to emulsify/lift dirt 4. Hose or pressure wash off all the soap (rinse it off) 5. Do a conventional 2 bucket wash Is this what everyone does? Steps 1-4 wouldn't really get it all clean, would they?
06-10-2018, 11:52 AM | #34 | |
Drives: 2016 2SS M6 Mosaic Blk Met-SOLD Join Date: Jun 2016
Doing Steps 1-4 is a Touchless Wash. Use a blow dryer for touchless dry.
Official Detailer of CamaroFest 8 & 9
https://www.autogeekonline.net/forum...st-8-pics.html https://www.camaro6.com/forums/showt...=521655&page=1 https://www.camaro6.com/forums/showt...=547470&page=1 https://www.camaro6.com/forums/showthread.php?t=527474 No one on Earth has detailed more Camaros. http://KirkTheDetailer.com |
06-10-2018, 02:13 PM | #35 | |
Sure, why not?
06-12-2018, 01:04 PM | #36 |
Drives: Toyota Avalon Join Date: Jun 2018
What soap do you guys recommend to use with soap cannon? I've never used soap canon before and I've just be using Meguiar's Gold Class Shampoo & Conditioner for my cars (ZL1 is on the list )
06-12-2018, 02:53 PM | #37 |
Drives: 2016 Blue 2SS Join Date: Mar 2016
chemical guys honeydew is my go to for super foam.
06-13-2018, 10:56 AM | #38 |
06-13-2018, 01:56 PM | #39 |
06-13-2018, 04:15 PM | #40 |
Drives: 2024 ZL1 M6, 1969 Cessna Skylane Join Date: Jun 2018
I got mine from Amazon. The one in the link comes with a set of 5 pressure washer nozzles. The also have the cannon by itself for a little cheaper, but I’m always losing the nozzles and for $3 it’s worth having spares.
I’m going to wash my airplane tomorrow with it. My gas power washer is kaput, so I got an electric one from Lowes that does 1.2 GPH @ 2000 psi, so I’ll see how it does with that. I’m also working on an ionized water setup for spotless rinse, so I’ll probably make a post if that turns out successful. |
06-17-2018, 08:16 AM | #41 |
Camaros Of Northwest Ohio
For my foam cannon, I have been using Chemical Guys Maxi-Suds II Super Suds Car Wash Soap in the Cherry Scent. I like it because of the thick shaving cream type soap I get from the cannon, the thick bubbles I get in the soap bucket and the slick feel from the microfiber wash pad on the paint, but at some point I would like to try the CarPro foaming soap products. I think there may be a small advantage using an SiO2 system of products that fit in with my CQuartz and Reload regime. I think there is going to be a big cost difference, but need to dig into that too.
Thoughts? Bill
2023 2SS 1LE Red Hot
2016 2SS Black / Black & Arenaline Red (sold) 2023 GMC Canyon Denali 2013 2SS / RS - AGM / Jet Black (sold) 1970 1/2 Z/28 Classic Copper / Tan (sold many years ago) |
