05-31-2018, 03:57 PM | #15 |
Camaros Of Northwest Ohio
2023 2SS 1LE Red Hot
2016 2SS Black / Black & Arenaline Red (sold) 2023 GMC Canyon Denali 2013 2SS / RS - AGM / Jet Black (sold) 1970 1/2 Z/28 Classic Copper / Tan (sold many years ago) |
05-31-2018, 05:11 PM | #16 |
Drives: 2019 zl1 6 speed Join Date: Jul 2017
I cut the top off of a water bottle and just hold it onto the foam cannon fill tank. Easy and free! Ish
06-02-2018, 07:21 AM | #17 | |
Thank you Al Oppenheiser!
My cheapo foam cannon with Carpro Reset makes a pretty nice foam with my gas PW. Top valve all the way closed. As far as I can tell it's identical to the one Kirk posted above.
06-02-2018, 07:45 AM | #18 | |
Drives: 2017 ZL1 A10 Join Date: Nov 2009
https://www.amazon.com/Cannon-1-10mm...or+foam+cannon Everything I have read and seen it will produce a shaving cream thick foam on 2000PSI electric PWs. Going to try mine this weekend with a 3100PSI gas PW. Should be interesting. |
06-02-2018, 07:54 AM | #19 | |
06-04-2018, 01:42 PM | #20 |
Daily Driven 1LE
Drives: 2018 1SS 1LE Join Date: May 2018
So I'll be the one to ask. Is anyone using a foam gun with a $100-200 range electric pressure washer?
2018 1SS 1LE
06-04-2018, 02:58 PM | #21 |
Drives: 2016 Blue 2SS Join Date: Mar 2016
heres a question do you put the soap in first or water first? I try to put the soap in first, but it just becomes a foaming mess when trying to fill it up, any trick to get that to not happen?
06-04-2018, 04:17 PM | #22 | |
Drives: Challenger SP Shaker/Arcadia Denali Join Date: Jan 2016
Yes actually, i just got this one for $109 on amazon or as low as $85 without the hose reel parts, been working like a dream and comes with the foam gun attachment. https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 |
06-05-2018, 06:20 AM | #23 |
06-05-2018, 06:26 AM | #24 |
I fill my canon bottle to about 80% full first with hottest water I can get from kitchen sink. Then add soap 3-5oz, screw on top, and rinse off bottle of any soap spillage so it’s not slippery. Slowly rotate back and forth to mix but don’t shake.
06-05-2018, 07:14 AM | #25 | |
Bill
06-05-2018, 11:21 AM | #26 | ||
Drives: 2016 2SS M6 Mosaic Blk Met-SOLD Join Date: Jun 2016
I put the soap in first then tilt the bottle and fill slowly with hot water.
Official Detailer of CamaroFest 8 & 9
https://www.autogeekonline.net/forum...st-8-pics.html https://www.camaro6.com/forums/showt...=521655&page=1 https://www.camaro6.com/forums/showt...=547470&page=1 https://www.camaro6.com/forums/showthread.php?t=527474 No one on Earth has detailed more Camaros. http://KirkTheDetailer.com |
06-05-2018, 01:16 PM | #27 |
Drives: 2017 50th Anniversary 2SS Join Date: Sep 2016
Watch out for some of those Electric PW's. They don't have the common quick change connector on the end of them that every soap cannon pretty much uses. Just something to watch out for..
06-05-2018, 04:09 PM | #28 | |
Drives: 2023 Black ZL1 Auto Join Date: Oct 2009
A trick I saw on a YouTube video for filling the soap bottle was to pour the soap in first, then hold the bottle in the wash bucket under water to let the water slowly fill the bottle. It seems like a good idea and easier than holding it under running water. |
