01-15-2018, 03:05 PM | #29 |
Drives: 17 SS a8 Join Date: Feb 2010
Can you share your dyno numbers and type of dyno?
best et 5.83@121 with the 5.3 http://www.camaro6.com/forums/showthread.php?t=465472 |
01-15-2018, 07:54 PM | #30 |
Drives: 2016 2SS Camaro Join Date: Apr 2014
It’s around 950 on the c16 and it’s a dyno something I can’t remember
01-15-2018, 07:59 PM | #31 |
950 sounds pretty low for your pass, but hey 950 is pretty stellar no matter how fast you run. Your tune is the key, tranny is right on and the car leaves great with 1.30 plus 60' times.
01-15-2018, 08:15 PM | #32 |
Drives: 66 Chevelle SS Join Date: Mar 2013
I'd love to see that car line up next to my friend's new Demon. That would be freaking hilarious. It would twist his head around in a 360* twist. I think that's the quickest new Camaro I've seen.
66 Chevelle SS 396
91 octane Driver n/a 6.44@105.78 1/8th mile |
01-15-2018, 08:20 PM | #33 |
Like i said idk exactly what it made at the time of that 8.84 pass cuz we had a degree or degree and a half more timing in it during that pass than when we made 945 on the dyno. But then again the 8.84 pass was a hot lap and had coolant temps at 200+ and iat around 150 and we had some belt slip so it made 23 lbs most the way
01-15-2018, 08:28 PM | #34 |
Drives: Camaro 17 SS Join Date: Jan 2017
Congrats! Still on stock crank? Water to air intercooler?
01-15-2018, 08:31 PM | #35 |
Drives: 2017 1SS camaro ,2SS a 68 + 08 C6 Join Date: Dec 2017
CONGRATS MAN WAY TO GO !!I remember my first 8 second time slip in my first gen camaro , about 14 years ago 8.79 at 149-150 something . A 540 Big block with dart heads and a single stage bigshot plate. Made 860 HP at the crank without nitrous in a 3,000 lb car .
01-15-2018, 09:34 PM | #36 |
01-15-2018, 09:37 PM | #37 |
Hell yeah that’s awesome for its day!
01-16-2018, 04:55 AM | #38 |
Op are you on the stock diff?
01-16-2018, 07:27 AM | #39 |
Get that belt slip fixed and it will run quicker. Great job Kevin.
01-16-2018, 07:41 AM | #40 |
Drives: Duramax Join Date: May 2017
You guys got me beat.
Back in the day (1980s), (when I was very poor), my very 1st Gen1 car we ran a N/A Single Carb 468cid (fed with Oval Port Heads), in a 3200lb street car on 10in radials and went 10.50's with a TH400. No we didn't squeeze it either!!! |
01-16-2018, 07:43 AM | #41 | |
I'd love to see your Bumpstick specs and your heads on a flowbench |
01-16-2018, 08:15 AM | #42 |
The heads are not ported. Still stock. The cam is only 220s on the intake duration. We shift at 7300.
If we can iron what few little bugs we had out, and get a cooked down glory run, 70s are possible. |
Thread Tools | |
