03-09-2024, 11:34 AM | #1 |
GA_ZL1
Drives: 2023 ZL1 1LE Join Date: Feb 2019
ZLE A10 Tranny Flush: one-use bolts?
Hi All:
I've had my 2023 ZL1 10-speed auto transmission fluid serviced once, and I'm going to be doing it again because GM recommends doing so every 15 hours of track driving. I purchased the appropriate filter and gasket (see screen shot), and I'll use the appropriate Dexron ULV auto-trans fluid. My question is whether there are any single-use bolts I need to get? Geoff (h018871) has a nice post about one-use bolts for his 2020 ZL1 (https://www.camaro6.com/forums/showp...1&postcount=61), stating that this bolt kit (GM # 22688153) was needed. I can't tell, however, whether this applies to the A10 in my 2023 ZLE. Does anyone know if I need to get this kit, and if so, which one? Or are there one-use bolts at all? Thank in advance! Jim FYI two related threads: * There’s a great thread by Stephen12ZL1 about an ATF flush on our A10 ZL1s: https://www.camaro6.com/forums/showt...10+fluid+flush) * For those of you preparing your ZLEs for track, you'll find some great feedback to a query I made about a year ago when I got my new 2023 ZLE and was getting it prepared for my first track use: https://www.camaro6.com/forums/showthread.php?t=612681
1989 Toyota Supra; 1993 Mazda RX7; 1993 C4 Coupe, 1993 C4 Convertible; 1994 Acura NSX; 1997 Acura NSX-T; 1998 Acura Integra GS-R; 2000 Acura Integra Type R; 2001 Porsche Turbo; 2007 Porsche GT3; 2011 Porsche GT3RS; 2014 Lamborghini Gallardo; 2015 Porsche Turbo S; 2016 Porsche Cayman S; 2016 McLaren 570S; 2017 Acura NSX; 2017 Camara SS 1LE; 2017 C7 Grand Sport; 2018 Camaro ZL1 1LE; 2019 McLaren 600LT; 2022 Lambo Huracan Evo RWD; 2023 C8 Z51 Coupe; 2023 Camaro ZL1 1LE, 2023 BMW M2 (and then there are sport bikes, but I’ll spare you those).
03-09-2024, 12:22 PM | #2 |
Drives: 2022 1SS 1LE A10 BCD WCT+PDR Join Date: Mar 2008
22688153 is not the # you need. I'm not seeing it in that thread.
Kit # 24298876 contains the one time use bolts you need, as referenced in the first thread post you linked.
03-09-2024, 02:20 PM | #3 | |
GA_ZL1
Thanks. So, the kit is as shown in this screen shot? What do these? Hold the AT filter in place? Do I need to also replace the series of shorter bolts that hold the cover in place? Sorry if I'm being duh. I just want to provide all the parts needed to the speed shop that works on my car. TIA. Jim
03-09-2024, 02:33 PM | #4 | |
GA_ZL1
03-09-2024, 03:49 PM | #5 |
The bolts that secure the transmission oil filter are aluminum and one time use, they are the ones that come with the kit and have no weight to them.
03-09-2024, 04:02 PM | #6 | |
And the small bolts that hold the pan on are reusable, nothing to worry about there.
