12-25-2012, 10:26 PM | #1 |
KaBoom1701
Drives: 13' ZL1 Red M6 Join Date: Dec 2012
TapShift!
Ok, so I'm a noob at this!
How, when and where with this TapShift thing? I just crossed the 3K mark on my card so now I'm not so scared to mess with hard shifting the tranny a bit. Been racing around town in auto and now I'd like to explore this TapShift thing... When should I use this mode. How to use it? Shifting at what RPMs' and in what gear. From what I've read around here the tras seems to shift itself when you hit high rpms....I think? Any help / info would be great. KaBoom |
12-25-2012, 10:39 PM | #2 | |
Drives: 2015 2SS/RS Join Date: Apr 2012
Personally I rarely use it, if at all. Putting it into 'M' and letting it shift itself in Sport Mode works fine for me. The car handles itself pretty well in that mode. Occasionally I may tap the buttons up or down to coax the car to change gears so I don't have to give so much go pedal to force a down shift (or if its being lazy with the up shifts).
2015 Camaro 2SS/RS SIM
2016 Jeep Wrangler 2DR Willys Wheeler 1993 C1500 Single Cab Stepside 5.3L LS Swap |
12-25-2012, 11:04 PM | #3 |
Drives: 2010 Join Date: May 2010
Get up to 40 MPH in auto, shift into sport mode, shift down to second gear, punch the gas.
12-25-2012, 11:14 PM | #4 |
It's pretty user proof. Just tap the left paddle (i believe I'm assuming cause I have a manual) to downshift and floor it at anytime. If you have it in manual mode it will stay in whatever gear you put it in until you tell it to upshift or till you are going to slow for the gear. No risk to rev to high the computer will keep you in line. Have some fun
Mods: BBK Intake, BBK LT's and High Flow Cats, Corsa Cat-back exhaust, Hurst short throw shifter, SLP skip-shift eliminator. 7/1/09 Placed order for IOM/IO int/ SS/RS 6M 9/26/09 Took delivery! |
12-26-2012, 12:04 AM | #5 |
The car will downshift automatically when going to slow for the gear but it will not up shift for you. You will hit the rev limiter until you shift. Have fun with it!!
12-26-2012, 01:23 AM | #6 |
Drives: '13 Camaro 2LT/RS Join Date: Sep 2012
Side question guys
so, do I release gas pedal completely to upshift, then once I shift I floor it again?:P or do I slightly let it go, shift, and then keep on going with flooring? |
12-26-2012, 01:27 AM | #7 |
No need to do anything w/ the gas pedal unless you want to try and make it sound like you are driving a manual.
12-26-2012, 01:30 AM | #8 |
12-26-2012, 07:26 AM | #9 |
Go out to the country. Shift into "M", or Sport mode. Step on the gas with a little gusto. Tap the right paddle when it feels right. Left paddle to downshift. Do this for a while, punching it a little harder each time, and (as others have said) "have fun with it". You won't hurt anything. No need to let off gas when paddling through the gears.
2013 1SS/RS Coupe L99, Stainless Power Works LT Headers, SCT X4 Custom Tune from RDP, CAI Inc. Air Intake w/ Apex Scoop, VMAX CNC Ported Throttle Body, Solo Axle-Back Exhaust w/ J-pipes, Apex Catch Can, Husky Splash Guards, Heritage Grille, 3D Carbon Rear Spoiler, Oracle Chrome Turn Signal Bulbs, GM Reverse Light Trim Billets, Gorilla Black Locking Lugs, Emblem Pros Retro SS Badges/Custom Retro SS Kickplates/Under-hood Bowtie, 35% window Tint, Nitto Motivo Tires (6-8-18)
12-26-2012, 07:48 AM | #10 |
Drives: '12SS/2SS/45TH-'06 2500HD/Silverado Join Date: Jul 2012
I've driven mine in tap shift mode plenty...let me tell ya, it's a whole lotta fun my friend. As for how, when, where and why, everybody else has covered that for you. Go have some fun. It's the closest you get to a stick w/automatic!
2012 Camaro SS 2SS 45TH Anniversary Edition
12-26-2012, 08:08 AM | #11 | |
Drives: 2012 2LT/RS Join Date: Oct 2011
In fact using the tap makes me yearn for a standard....sigh. |
12-26-2012, 08:24 AM | #12 |
TRI COUNTY TAMPA
Drives: 2011 1SS/RS VR/BLK A6 Join Date: Jan 2011
Launch from a dig in 1st and you will never want to be in auto mode again. 1st is wicked. Sadly it takes plenty of practice to get a super clean 1, 2 shift.
12-26-2012, 08:39 AM | #13 |
Guest
Drives: bbbbbb Join Date: Dec 2012
Use it however you like. I use mine some but not a lot. A few things to keep in mind. It can be used in Drive or sport modes but the 2 act different. This is from my experience using it. When in Drive, you can upshift or downshift as normal and trans will still shift automatically on its own with or without the paddles. Okay now in sport mode, trans will act and shift normally until you hit either tapshift paddle, when you do you are totally manual it will not upshift for you, when you come to a stop it will downshift but mine will not shift back up until the up paddle is tapped. It will not let you upshift in either mode if RPM is too low. In sport mode you will hit the engine limiter at 7k if you don't hit the tapshift, been there done that on more than one occasion. Usually because I keep forgetting the tapshift takes what seems like close to a second to shift after being tapped I seem to misjudge it and hit the limiter in first going to second. I use mine in drive mainly for downshifting to pass another vehicle this way I don't have to mash the pedal to get it to downshift. I rarely use it in mode unless I really in the mood for playing around and that is rare.
Read the manual and understand it then play to your hearts content. Dean. |
12-26-2012, 08:51 AM | #14 | |
7 year Cancer Survivor!
Drives: 17 Cruze RS, 07 G6 GT, 99 Astro Join Date: Dec 2007
For more information you can consult your owners manual. I usually use it for the mountains, when descending steep grades you can get it to hold in a lower gear and not have to use your brakes too much to keep the car at a safe speed.
The Bird is the word! |
